A/C Compressor Done for?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by danbow, Jun 30, 2017.
  1. Jun 30, 2017 at 12:50 PM
    danbow
    danbow [OP] Member
    Daniel
    Texas
    18 F150 Crew 4x4
    Symptom is that the A/C doesn't blow cold, feels cool, but not early as cold as it should be.
    First thought was that there is small leak and I'm low on refrigerant.
    I thought I'd just try the cheap route and buy an R134a refill can.
    PSI from system reads about right, 55psi according the can when 90+ ambient temp, but it is not steady.
    The compressor kicks on and off rapidly...on for a few seconds then back off, pressure spikes when compressor goes off.
    I may already know what I need to do, but just though I'd see if anyone had a similar problem.
    This is on a 2nd gen 6cyl FYI.
  2. Jun 30, 2017 at 12:52 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    I had a similar situation with a Dodge Nitro I used to own. I brought it to the dealership and they wanted almost $3,000 to fix it. I used one of those refill cans and PSI was all over as well. Filled the system until the can meter stabilized and it blew cold air for the rest of the time I owned it.
  3. Jun 30, 2017 at 12:57 PM
    danbow
    danbow [OP] Member
    Daniel
    Texas
    18 F150 Crew 4x4
    Thanks.
    PSI has seemed to stabilize when the compressor is on, but it keeps kicking off every few seconds causing the PSI to spike.
    I'm hoping I don't need a compressor... going to see if running around this afternoon makes any change. It's not unbearably hot with the A/C on, but it is on max and should be much cooler.
  4. Jun 30, 2017 at 1:15 PM
    elutheros
    elutheros Active Member
    Copperas Cove, TX
    07 Crew Cab
    Bike rack above bed Locking Fuel door
    I just got all my parts to replace my compressor. The failure symptoms usually include cool air on the driver side vents and progressively warmer air on the passenger side as the expansion valve begins to get plugged with debris from the dying compressor. Better to take it to an expert to check the r134 level rather than keep adding refrigerant as that can also cause it to fail. Could be as simple as a relay dying and triggering the on/off cycles. You can get the condenser, compressor, expansion valve, flush fluid and flushing kit for less than $400 if you want to replace the parts yourself and then get it charged by a pro.
  5. Jun 30, 2017 at 1:16 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Those freon cans are terrible. Pay a mechanic to properly evac and recharge the system. Don't buy cans!!!!!!
  6. Jun 30, 2017 at 1:17 PM
    Bebop
    Nick
    Flushing doesn't work for modern condensers. The passages are too small. If you have a catastrophic compressor failure, it's best to replace the condenser. Your never gonna get it clean and your just inviting failure for the new compressor.
  7. Jun 30, 2017 at 1:41 PM
    80schild
    80schild Well-Known Member
    Chad
    Flori-Bama
    2007 TRD Sport Access Cab
    Fast cycling on/off typically does mean the refrigerant is low.
  8. Jun 30, 2017 at 1:49 PM
    Pabloeeto
    Pabloeeto Well-Known Member
    Paul
    San Diego
    06 DCSB TRD Sport 4x4
    K&N filter, 3.5 Aux input mod, Fox 2.0 Coilovers, Fox 2.0 Resi Shocks, Element UCAs, Old Man Emu Dakar Leaf pack.
    From what i've learned about A/C is to have the pro's do it. I shot the parts cannon at my old Honda on this exact same issue and got nowhere, ended up replacing Compressor, Pressure switch, freon, receiver/dryer etc. roughly $600 in parts.
    I think I had a clogged condenser or something, never did figure out the real culprit since I totaled the car soon after.
    Bebop likes this.
  9. Jun 30, 2017 at 1:56 PM
    Bebop
    Nick
    I've seen weak clutches do this also. I have also seen a failing pcm do this too. But fast on and off typically is a low charge due to the low pressure cut off switch doing its job.
  10. Jun 30, 2017 at 2:11 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    It can mean just the opposite - system is overcharged. Not saying it is - just saying that short-cycling is sometimes the result of overcharging.
    I'd trust a NOLA hooker with my wallet B4 I'd believe a reading produced by a suicide recharge kit.
    CurtB likes this.
  11. Jun 30, 2017 at 2:19 PM
    danbow
    danbow [OP] Member
    Daniel
    Texas
    18 F150 Crew 4x4
    Interesting, thanks for the input so far.
    Just got back from driving around in 95+ weather, seems to be cooling a little better. Compressor still quick cycling though. Freon can has a gauge that can be used separately from the can. Tested the pressure when I got home and it looked pretty good. I don't trust the cheap gauge 100%, but it seams to be ok. I'm hoping I was just low on Freon, maybe a small leak somewhere.
    If this didn't fix it, I'll have a mech take a look.
    SC2SC likes this.
  12. Jun 30, 2017 at 2:25 PM
    SC2SC
    SC2SC Likes Pineapple on Pizza
    Jonathan
    South of Charlotte
    2014 DCSB MGM TRD OR 4X4
    Icon Custom Build Custom Exhaust • SOS Sliders• RokBlokz
    @danbow
    Similar happened to me- on my 2014 just a couple weeks ago.
    Small leak of coolant. Dealer put a dye in the coolant to detect leak. Found leak and debris/metal shavings. Replaced everything from compressor to dash vents- under my 36 k warranty. Had to take back 2 days later due to faulty O rings/freon leak. Good to go now; quiet and cold!
  13. Jun 30, 2017 at 2:30 PM
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    You need a proper manifold/gauge set, --the low pressure side is just 1/2 of the story.
    The pressures should be as indicated in this table:
    If not use this table to determine the likely cause:
    If it's overcharged make sure no one is watching when you vent it...
    Tex-Tac, danbow[OP] and Bebop like this.
  14. Jun 30, 2017 at 2:38 PM
    Bebop
    Nick
    Coolant or refrigerant (freon) 2 different things
    SC2SC[QUOTED] likes this.
  15. Jun 30, 2017 at 2:46 PM
    SC2SC
    Jonathan
    South of Charlotte
    :notsure: Whatever makes it cold...?
  16. Jun 30, 2017 at 2:48 PM
    Bebop
    Nick
    Coolant is antifreeze. That goes into the engine cooling system. Refrigerant is for the ac
  17. Jun 30, 2017 at 2:59 PM
    Jonas
    Jonas Boogerrrrrr!
    Springfield, OR
    05TRDSport
    Most leaks are from the Schrader valve. It's like the valve stem on a tire where you fill the refridgerant. Put a little soapy water on it and look for bubbles. Kinda OT but something to look at before a shop tries to rip you off. Easy fix too, only a couple bucks from parts store.
  18. Jun 30, 2017 at 3:04 PM
    Bebop
    Nick
    If you open up the system you will need to apply a deep vacuum to remove all the air and moisture before charging. Unless you have a vacuum pump or a recovery unit this is not reccomended to do at home.
    cliffyk likes this.
  19. Jun 30, 2017 at 3:09 PM
    cliffyk
    Cliff
    Saint Augustine, FL
    To replace the Schrader valve(s) you will need to vent the refrigerant--so you'll need both a real gauge set and a vacuum pump ( ) to recharge it.
    Do NOT leave the system open for any longer than absolutely necessary to actually change the valves...
  20. Jun 30, 2017 at 3:09 PM
    cliffyk
    Cliff
    Saint Augustine, FL
    Beat me to it...
