A/C Compressor Drag on engine
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Curtamous, May 3, 2010.
  1. May 3, 2010 at 2:01 PM
    Curtamous
    Curtamous [OP] Member
    Austin, Tejas
    06, TRD Off Road, Super White, SB..
    Newbie to taco's and tacoworld here :) I'm likin' all the brotherly love I read and see getting addicted to tweakin' my ride!
    Just bought an 06, TRD, 44k, 2WD, crew cab, SB ..
    Question:
    - Seems there is a significan drag when you press the AC compressor button. It's almost like hitting a 40mph headwind. Could this be some sort of vacuum issue or something? I know this is common with most auto's, but seems excessive.
    I get the same thing s o m e t i m e s when I just let off the accelerator without the AC being on.
    I welcome your thoughts!
    Thanks!
  2. May 3, 2010 at 2:02 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    its normal :) at least i know damn well i feel it
  3. May 3, 2010 at 2:08 PM
    Jester243
    Jester243 rabble rabble rabble
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    is this a 4cyl or a 6?
  4. May 3, 2010 at 2:11 PM
    08pretaco
    Oliver
    az
    ^ its a 06 dcab....pretty sure v6
    only 1st gens had a dcab 4 banger
  5. May 3, 2010 at 2:18 PM
    BakoTruck
    BakoTruck Well-Known Member
    Herbie Hancock
    Bakersfield, CA
    05 PreRunner TRD
    Mostly stock for now, I have added a cb radio, various cheap mods and I plan on adding aftermarket wheels and other items in the future.
    Yeah, my truck acts the same way and I have seen others post the same thing. I took my truck in to get it checked out back in 05, they said the A/C compressor looked fine, along with everything else. I found the best thing to do is to turn it on when you get over 50 MPH or so or a higher RPM.
    So I wouldn't worry too much about it.
    Welcome to TW.
  6. May 3, 2010 at 2:22 PM
    Curtamous
    Austin, Tejas
    Thanks guys.. I feel better now.. kinda. Yes, V-6.
  7. May 4, 2010 at 6:46 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Definitely normal. I have an electric fan and get the same reaction when the fan kicks on. Seems the AC and alternator startups drag on the engine more than vehicles I've had in the past.
  8. May 4, 2010 at 8:49 AM
    thinkingman
    thinkingman Well-Known Member
    redmond WA
    2006 dbl cab 4wd 6sp
    Foglights are for fog, not oncoming traffic!
    There's a mod to disable the automatic compressor on defrost.
    Looks simple and worthwhile.
