A/C compressor issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by chriswvt, May 19, 2017.
  1. May 19, 2017 at 3:41 PM
    chriswvt
    chriswvt [OP] New Member
    2010 Grey Tacoma TRD
    A/c lights flashing, with a loud horn like noise coming from the compressor, took it to a shop and they said they had to replace everything in my system and it'll run me $2000, I was wondering why they would have to do that or if I could just replace the compressor?
  2. May 19, 2017 at 3:54 PM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    Go to a different shop, and have them tell you exactly what is wrong.
    Jimmyh likes this.
  3. May 19, 2017 at 8:32 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I can only guess, but if the compressor had blown up it has sent shredded metal throughout the system.
    I would go with what CurtB said as he has excellent advice. The shop you took it to seems to be quite vague on details...
  4. May 22, 2017 at 12:19 AM
    igno1tus
    igno1tus Small member
    Lehigh Valley Area , PA
    '07 Tacoma Access Cab TRD Off Road
    I just had mine done a few days ago and they replaced the compressor, expansion valve and condenser(condensor?) . Also recharged the system , everything was 1558 . I got a year warranty or 12k miles on the compressor and 6 month warranty on the refill . It was a local Midas shop that did the job .
    :fingerscrossed:
    It's ice cold now and works great . They told me to warranty the parts for the compressor they had to do the condenser also ( I don't know how true that is but that's what it took to get. Warranty ) and I wanted the job done right and not half assed .
  5. May 22, 2017 at 8:17 AM
    Caltech90
    Caltech90 Well-Known Member
    '19 TRD OR T4R
    I wonder if they have an orifice tube like the old Chevrolets.
  6. May 22, 2017 at 2:59 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    That would be like the inline filter to the evaporator. The answer is yes. It is located in the line going through the firewall into the expansion valve.
  7. May 22, 2017 at 3:11 PM
    Caltech90
    '19 TRD OR T4R
    Can he just check that for metal shavings? If there isn't any then would you still have to change out the entire system?
  8. May 22, 2017 at 8:19 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    If someone is doing this job they should pull that filter and replace it. It is only there to protect the expansion valve and evaporator from debris. Everything outside still has the potential to be contaminated.
    A shop isn't going to honor any warranty unless they replace the filter dryer which is made as part of the condenser coils.
  9. May 22, 2017 at 8:32 PM
    igno1tus
    So that's why they told me they had to replace my condenser
  10. May 22, 2017 at 8:43 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Yes. If you don't replace it all then there is a chance that pieces of the blown compressor will eventually get back to the new compressor and blow it also.
    igno1tus likes this.
  11. May 22, 2017 at 8:48 PM
    igno1tus
    Is there a way to flush/purge the system ? So you know there is no pieces of compressor in the system ? Or does the condenser "catch" it all?
  12. May 23, 2017 at 7:55 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    The condenser/filter/dryer assembly usually catches a lot of it. Anything that doesn't get replaced will/should be cleaned of any debris.
