A/C compressor lock up
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacomonster23, Jul 24, 2015.
  1. Jul 24, 2015 at 12:48 PM
    tacomonster23
    tacomonster23 [OP] Well-Known Member
    06 Taco
    Truck only has 74k and yesterday my compressor locked up when i tried to turn on the air making an awesome screeching noise from the belt. Anybody else have this kind of problem? Im gonna be taking it in for the frame recall and like 4 other open recalls and ill probably have them take care of that too while its there. Hopefully my baby is gonna get a few more new parts $$$
  2. Jul 24, 2015 at 3:43 PM
    Drivesector
    Drivesector Well-Known Member
    TRD sport
    A/C compressor will probibley cost a fortune to have the dealer do. If it's locked up and want to save some cash get a replacement, install, borrow or rent a vacuum pump and pump it down. Refll with 134a and should be all set after checking pressures. Good luck whatever you decide.
  3. Jul 24, 2015 at 4:18 PM
    tacomonster23
    06 Taco
    Yeah just checked the price at my work. Employee price is around 200 for the compressor and 500 for the clutch..thats not including a condensor which ill most likely need. Looks like its time for surgery.
  4. Jul 24, 2015 at 6:11 PM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    Does the new compressor not have a clutch already installed?
  5. Jul 24, 2015 at 7:56 PM
    tacomonster23
    06 Taco
    I guess not, the parts guy at my work said they come seperately but an aftermarket compressor with clutch is about 250 but in my opinion id rather put oem parts back in.
  6. Jul 28, 2015 at 10:04 PM
    shthawk
    shthawk Active Member
    BC
    06', dbl cab, SR5, auto
    3" full OME lift, LR upper control arms, 33" KO2, heated mirror mod, 1000w inverter.
    probably too late but 9 times out of 10 all you need to do is the clutch, long as the little 8mm bolt isn't seized on the front. saves you from a compressor and evac/recharge
