A/C compressor noise 08 4.0 liter
Discussion in '2nd Gen. Tacomas (2005-2015)' started by billybobsgoat, Oct 16, 2008.
  1. Oct 16, 2008 at 4:58 PM
    billybobsgoat
    billybobsgoat [OP] Member of the Goat Army
    08 PR silver 4.0 manual TRD O R
    I dont drive my truck daily, I have a company truck. but if the truck sits for a day or two I go out to start it up and after its running for a few seconds or so I turn on the A/C and the compressor makes a short groan when it kicks on very quickly is this normal??
  2. Oct 16, 2008 at 5:35 PM
    1bad03snake
    1bad03snake Well-Known Member
    Baytown,TX
    4x4 TRD
    none but please give me your info.
    I would like to know as well, mine does it sometimes.
  3. Oct 16, 2008 at 5:51 PM
    Drew793
    Drew793 Well-Known Member
    New Jersey
    08 TRD Off-Road V6 Auto
    Weather Tech window shades, Roll-N-Lock cover with cargo manager, Led interior bed lights, EZ down tailgate strut, SpiderTrax1.25" wheel spacers, tinted windows, second filter removed, Grillcraft Mesh upper and lower grill, Castrol Syntec.
    Mine does it also. Start the truck and immediately put the ac on,,, the compressor clutch makes an unpleasant sound. My 2007 4 cyl. Tacoma did it also so. While the truck is in motion and the compressor cycles according to the temp it doesn't make the noise. It seems to just be isolated to the initial start up.
  4. Oct 16, 2008 at 7:58 PM
    billybobsgoat
    I guess I'm not alone on this. Thanks for the quick responses.
  5. Oct 17, 2008 at 10:49 PM
    itsmyturn
    itsmyturn Well-Known Member
    Victorville, CA
    08 dbl cab TRD sport
    afe Pro-Dry S dropin, Readylift leveling kit, TRD skid plate, Alpine CDA-9887, 6K D2S HID
    mine does this also, at idle at a stop just an annoying groan. thought maybe it was the expansion valve causing a change in the refridgerant
  6. Oct 17, 2008 at 11:16 PM
    willard417
    willard417 Yeah
    Luke
    beaver county, PA
    06' access cab. 2.7L
    alpine head unit, removed secondary air filter, 18" XD Rockstars. 285/60/R18, 3" OME 884/AAL OME shocks all around.
    yeah i've got the same problem. I also have no power when i'm running the a/c. kinda sucks
  7. Oct 18, 2008 at 12:40 PM
    billybobsgoat
    I wonder if the dealer will do anything about this?? :confused:
  8. Oct 19, 2008 at 11:04 AM
    wawireguy
    wawireguy Well-Known Member
    Mine makes a screech sometime.. More quality Toyota engineering for sure..
