A/C compressor not turning when the motor is running.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hdgtaco, Apr 1, 2020.
  1. Apr 2, 2020 at 5:58 PM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    Correct. If the clutch is not engaged, it serves as an idler pulley.
  2. Apr 4, 2020 at 2:40 PM
    hdgtaco
    hdgtaco [OP] Member
    2009 TRD
    none
    OK, finally had some time to check a couple of things on the A/C today. I did mark the pulley on the compressor and it is spinning. ( feel dumb for not thinking it was spinning) The clutch is not engaging when I put the A/C on, so I did the easy things like change the MG relay and A/C fuse. Still not engaging. Then I thought I would check the receiver/dryer window to see if there was any R134 in the system. Well as you all probably know there is no receiver/drier on a 2009 Tacoma or( I can’t find it). What should I check next?
  3. Apr 4, 2020 at 2:43 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    You can check to see if you have any refrigerant by depressing the schrader valve needle with a small screwdriver. If its "spritzes", you have some refrigerant. Only try this with the large tube/pipe, it's the low pressure side.
  4. Apr 4, 2020 at 2:48 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Low on refrigerant. There is a low pressure switch that keeps it from turning to keep you from trashing the system.
    Jimmyh likes this.
  5. Apr 4, 2020 at 4:48 PM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    Someone that knows what they are doing. Sorry to be so blunt, but JFC! Have some one put a set of gauges on it.
    Fullboogie, koditten and Muddinfun like this.
  6. Apr 4, 2020 at 5:14 PM
    koditten
    Kirk
    Central Michigan
    ...or that ^ when all else fails...
  7. Apr 4, 2020 at 6:20 PM
    Clearwater Bill
    Billy
    Largo Florida
    There is no sight glass. They disappeared when receiver / driers were replaced by accumulators, in the early '90's by most marquees.
    Not being rude, but your next move is to get a pro with a full set of r134a gauges to check it out.
    Muddinfun likes this.
  8. Apr 4, 2020 at 11:08 PM
    pyrite4t3
    pyrite4t3 Well-Known Member
    12 TRD OR AC
    Don't sweat it. Not all of us are experts on every facet of these trucks. As many have mentioned, you have reached the apex of DIY knowledge. Either barter with a homie, or pay a shop to find the culprit. Do it now before swamp ass season!
    Nobody knows everything, that's why we come here to trade our knowledge.
  9. Apr 5, 2020 at 6:46 AM
    hdgtaco
    hdgtaco [OP] Member
    2009 TRD
    none
    Thanks for all the advice I guess it will be time to have the professional take a look. Figured it was worth asking the question on this site before having the pros take a look. Will keep you posted.
    Thanks to all for sharing your knowledge!
    Clearwater Bill and koditten like this.
  10. Apr 5, 2020 at 8:06 AM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    What?! All five of my Toyotas - Tacos and 4Runners - have a sight glass. Including my '20. Want me to post up some pics?
  11. Apr 5, 2020 at 5:12 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Nevermind I was off.
  12. Apr 5, 2020 at 8:39 PM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    Pics please. I haven't seen a sight glass in years, and my taco doesn't have one.
  13. Apr 6, 2020 at 7:55 AM
    Fullboogie
    Dave
    Houston
    Well I'll be damned. I've got to halfway retract my comment. Someone explain why only 4Runners have sight glasses? My '08 had one nearly front and center when you popped the hood, and below you'll see a pic of my '20 - which even has a dedicated sight hole in the radiator cover. I ran out and checked my daughter's truck (the silver one in my sig) from firewall to condenser and there's no sight glass. I should have checked before commenting. Sorry guys!
  14. Apr 6, 2020 at 11:09 AM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    Well huh, that sure is a sight glass. I didn't believe you but now I do. Sight glasses went away years ago with manufacturers going to orifice/accumulator systems. My '10 Taco has a receiver drier and an expansion valve, no sight glass. The only way I can properly charge it is to empty it, then weigh in the freon. And at full charge and idle, the LP runs 55psi. That's about 60f at the evaporator. Which means it doesn't cool for shit. Run the rpm at 1500 and LP drops to 40-45 and cools great. The compressor just doesn't pump fast enough at idle.
  15. Apr 6, 2020 at 11:18 AM
    #35
    Fullboogie
    Dave
    Houston
    And if you're familiar with 4th gen 4Runners, the grill comes up with the hood. Right there on the left hand side is a block with the schrader valve and sight glass. So I wonder why 4Runners have them and Tacos don't? Very odd.
  16. Apr 6, 2020 at 11:26 AM
    #36
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    :notsure:
    I wonder too, and what is the charging procedure on it. Does it involve the sight glass?
  17. Apr 6, 2020 at 12:24 PM
    #37
    Fullboogie
    Dave
    Houston
    Nah, I've got the manifold and gauges and always charge using high/low pressures per ambient temp. To be honest the sight glass is useless.
    koditten likes this.
