a/c compressor relay
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ricki lee, May 18, 2017.
  1. May 29, 2018 at 6:36 PM
    #41
    bkrdave36
    bkrdave36 Well-Known Member
    Dave
    Wittmann,AZ
    06 Prerunner Double Cab Black
    Front OME Springs, Upper Control Arms, Icon Stage 3 Rear Leaf Springs, Durobump bump stops,Bilstein 5125 shocks, BFG All Terrain KO2 Tires, Avid Light bar and step rails, Victory 4x4 bed rack with Tepui Ayer Rooftop Tent, Anytime Fog light mod, Outside Air Temp Gauge mod, ImMrYo Rearview Mirror mod, Chinese Knockoff LED lights, Body Armor 4x4 Offroad Swingout rear tire carrier and bumper, Victory 4x4 Bed Stiffeners, Rattle can Custom Camo paint stripe, Truxedo Lo Pro tonneau cover, various Blue Ridge Overland Gear storage solutions in cab, thats it so far .... to be continued!
    This may be a stupid question....but what does an a/c amplifier do and how does it do it?
    Sorry but A/C is beyond me ( except for using it).
  2. May 29, 2018 at 9:42 PM
    #42
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    See the schematics in Post # 24.
  3. May 29, 2018 at 11:37 PM
    #43
    bkrdave36
    Dave
    Wittmann,AZ
    OK. I see the schematics. And the diagram showing where it is and how to install it.
    But that doesn't answer my question. I'm not an engineer, can you translate all that into somple English...what does it do and how does it do it? Or is it just a Ventura to make the air go faster? Please explain.
    Thank you.
  4. May 29, 2018 at 11:56 PM
    #44
    Jimmyh
    SC
    2012 Prerunner SR5
    No I cannot in in a reasonable amount of time and space I have on the forum.
    But If you look at the second schematic that shows the AC Amplifier as a block in the middle and it accepts various outputs from the AC Controls and sensors and uses the electronic logic circuits inside to turn on and control various things such as Turning on the AC Compressor Clutch or Controlling the Mode Servo Motor Position. If you are really interested maybe you could look into a course of auto electronics.
    Canufixit likes this.
  5. May 30, 2018 at 8:32 AM
    #45
    bkrdave36
    Dave
    Wittmann,AZ
    So its like the "computer" for the A/C.
    Go back to school!?! Hahahahaha!
  6. May 22, 2019 at 1:27 AM
    #46
    DimeGirlTX
    DimeGirlTX Member
    Marie
    Spring Tx 77373
    1997 Toyota Tacoma Extended cab 2.4, RWD
    Trying to keep it in shape and running nicely.
    I recently installed a AC/Compressor clutch and the connector on the truck and the new one do not match up. How concerned should I be about this? Is it OK to just remove the old and new connectors and just connect the wires? Is this a normal thing to do or not recommended?
  7. May 22, 2019 at 3:40 PM
    #47
    Jimmyh
    SC
    2012 Prerunner SR5
    The old connector and the new connector should look exactly the same. I see on your signature you have a 1997. If you bought the connector listed here in many discussions it probably is not the correct connector.
    If and when you get the correct blower connector you will have to cut and crimp or solder the wires.
  8. May 22, 2019 at 3:42 PM
    #48
    Jimmyh
    SC
    2012 Prerunner SR5
    https://www.tacomaworld.com/threads/heater-only-works-on-high.587143/#post-19591584
    Resistor and connector needed:
    Look at both connectors on the motor. I'd be willing to bet one or both of them are burned.
    If they have burn marks you need to replace the connector plugs.
    Part number 90980-10916 Connector
    Part Number 82998-12380 Wire and terminal
    Not sold as a kit, sold as each. So you will need one of the plugs and two of the terminal and wires.
    Connector:
    Terminals:
  9. Jun 15, 2019 at 5:44 PM
    #49
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    Jimmyh Just wanted to say you sure do add some great info and attachments. !!!
    Taccat and Jimmyh like this.
