A/C compressor replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Deez19, Sep 11, 2014.
  1. Sep 11, 2014 at 11:14 AM
    Deez19
    Deez19 [OP] New Member
    Dave
    Tazewell VA
    06 Tacoma access cab 4x4
    None yet!!!
    Has anyone changed the a/c compressor. Can you get away with just changing the compresso
  2. Sep 11, 2014 at 8:00 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    If it locked up or came apart internally. No, you would have to be the luckiest man alive if you did.
    What needs to be replaced is the compressor, filter / dryer and condenser at a minimum. ( The Tacoma Filter/dryer condenser is all one piece in front of the radiator ).
    When the compressor blew all the small shards of metal were sent through out the system.
