A/C COMRESSORS JUNK ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by greatfuldead, Oct 29, 2015.
How many taco owners, have had to replace the A/C compressor?
Poll closed Nov 5, 2015.
  1. YES, Mileage 50,000 to 100,000 or more
    0 vote(s)
    0.0%
  2. YES, Mileage Less than 50,000
    0 vote(s)
    0.0%
  3. NO, Mileage 50,000 to 100,000 or more
    33.3%
  4. NO, Mileage Less than 50,000
    66.7%
  5. Yes, It has been replaced twice
    0 vote(s)
    0.0%
  1. Oct 29, 2015 at 4:06 PM
    greatfuldead
    greatfuldead [OP] Active Member
    central ohio
    2010 accesscab 5sp 4cyl
    none yet
    I can't remember where I read that Tacomas have air conditioner compressors that are labeled DENSO, but are really junk made by DELCO. They are prone to failure and expensive to fix.
    I probably saw it on here, but I can't find it. I'm posting a poll to see if it's true.
    I'm thinking of replacing mine before it blows up and contaminates the entire system.
    I've got the blinking A/C light no cool syndrome, comes and goes.
  2. Oct 29, 2015 at 4:18 PM
    Drivesector
    Drivesector Well-Known Member
    TRD sport
    If the compressor is spinning free and you have blinking light it could be many things, not just compressor. Have you checked your belt, charge, pressures. Don't just fly to the worst case problem. If you have high pressure the high pressure switch will cut it out at higher rpm. If you have low pressure it's will cut out at lower rpm. Is your clutch fan ok?
  3. Nov 26, 2015 at 9:47 PM
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    I've got a 2010 regular cab 2WD automatic, and yes they do in have DELCO/Delphi-Harrison compressors. I've had my truck for more than 6 years and and a little over 55,000 miles. The A/C has never given me any trouble (aside from abnormal humidity in the summer of 2014 messing with the performance a bit) and numbs my fingers even on 90+ degree days.
    Anyway, with regard to your truck, I've never heard of the blinking A/C light on any vehicle, but it sounds like it's more of an electrical problem? Maybe it's a problem with the connection between the HVAC controls and the components under the hood (compressor, etc)?
  4. Nov 27, 2015 at 7:25 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Check your belt if it slips the compressor light will come on and go off.
  5. Nov 28, 2015 at 8:16 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    I've got two high mileage decade old toyotas in my garage with the original compressors and I live in one of the hottest cities in America.
    Luck of the draw?
  6. Nov 28, 2015 at 8:28 PM
    Clearwater Bill
    Billy
    Largo Florida
    :rofl::rofl:
    Polls indicate Trump will be the R nominee too. :anonymous:
  7. Nov 28, 2015 at 8:41 PM
    Justinlhc
  8. Nov 29, 2015 at 7:38 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I know of one guy who had an AC compressor fail. He was military stationed in Alaska and didn't use the AC for 2 years. Got transferred to Florida and it quit working almost as soon as he got there.
  9. Nov 29, 2015 at 7:42 AM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    Use it or lose it.
  10. Nov 29, 2015 at 7:43 AM
    jeverich
    jeverich Well-Known Member
    Jake
    PNW/Kodiak
    07 2.7 4x4
    OME 886/Old Man Doug Suspension Lift, ARB Bumper, Bruteforce High Clearance w/Swing Out, De-badge, Block Heater, Homemade IFS Skid, 7" Kragens, Blue Seas Fuse Block, BlitzPro Fogs, 12k BadLands Winch, BAMF Sliders, ARB Locker, 4.88s Yaesu FT-1900R, Larsen 150B NMO Mount Antenna
    This.
    My compressor seized about 20,000 miles ago (I'm at 156k miles now...). I rarely used my A/C up until that point anyways; as I was living in a climate that didn't require it. That being said, I preferred just to put the windows down if I needed to get cooler temps in the cab.
    Pulley still spins freely when the electromagnetic clutch is disengaged - but as soon as the clutch is actuated, the pulley seizes. I believe the failure is within the bearing assembly, which with this particular compressor is not a replaceable part.
    Disconnected the wire that actuates A/C compressor when the defrost function is being used... hasn't been an issue since.
  11. Nov 29, 2015 at 8:55 AM
    Clearwater Bill
    Billy
    Largo Florida
    Thus the problem. Lubricant is carried suspended in the refridgerant and needs periodic circulation. Everyone should run theirs, even in the dead of winter, at least 15 minutes a week. Folks who complain about the compressor running when in defrost mode should actually be glad it does.
    HBMurphy likes this.
  12. Nov 30, 2015 at 4:19 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Yep. I never could understand people crying because their AC came on during defrost like every other vehicle made.
  13. Nov 30, 2015 at 11:20 PM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    The compressor clutches go out a lot too, and that ain't cheap either.
    That's how I found the 2.7 and 4.0 use the same compressor. My truck now has a clutch assembly from an '06 4.0 bolted to my factory compressor thanks to my original's clutch rubber shearing off.
  14. Feb 4, 2016 at 5:01 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    My compressor seized up today in an awful howling hissy fit
    Oh joy
  15. Feb 4, 2016 at 5:06 PM
    NMW 4x4
    NMW 4x4 Wheels With Moose.
    Walt
    T8 R11 WELS, Maine
    '14 DCLB SR5 4x4
    My '07 had 210k on it when I traded it. Never had any compressor or any other A/C related issues. Never even recharged it. Still blew ice cold.
  16. Feb 4, 2016 at 6:33 PM
    GratefulTaco
    GratefulTaco Well-Known Member
    Alabama
    09 Super White Pre-Runner Double-Cab TRD Sport
    Previous tacoma lost a/c the day I looked at to buy. Negotiated for 2000$ less than asked. It had 38k miles at the time. Cost me around 1000 to replace. Toyota quoted me 1700 and didn't guarantee that price.
  17. Feb 4, 2016 at 6:36 PM
    Bishop84
    Bishop84 Well-Known Member
    There are many aftermarket compressors out there now, they cost around 600$ canadian, better than the 1000$ for the clutch and new compressor. I also suggest replacing the relay as an old school repair habit due to the arcing caused by the worn clutch.
    Most I've changed are around 160km/100miles.
  18. Feb 4, 2016 at 7:40 PM
    skiergd011013
    skiergd011013 Well-Known Member
    2010 TRD Offroad 4x4 AC SSM
  19. Feb 4, 2016 at 8:33 PM
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    No compressor issue but I've replaced my evaporator core already with 42k on it. Shit happens
