A/C Condensation Line
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FL_TRD Sport, May 22, 2023.
  1. May 22, 2023 at 6:05 AM
    FL_TRD Sport
    FL_TRD Sport [OP] Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    Hi all. Yesterday after a two hour highway drive I notice there was liquid beaded up on the front passenger side floor mat. It was definitely water. When I checked it more closely I noticed there was a small wet area on the carpet starting from in front of the center console to the floor mat. Figuring from my reading here that it was probably a clogged A/C condensate line I figured I'd monitor it on the drive home. After two hours of highway driving, not a drop. I just checked it again this morning and the small area that got wet on the carpet was bone dry and there was nothing on the mat. On the way down it was a hot, humid south Florida day that would typically cause a lot of condensation. The drive back was at night. The truck is still under warranty so I'd take it back to the dealer to let them clear the clog, but I can't very well take it there with no sign of a clog. Do these things ever clear themselves or is it possible it could be a partial clog that just got overwhelmed with the amount of condensation on the drive down? Any insight would be appreciated. Thanks!
    TRDRed and cryptolime like this.
  2. May 22, 2023 at 7:55 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    I would run the AC in the driveway for a few minutes and see if any condensation comes out of the drain line. You can see it pretty clearly.
    TRDRed, Chew and FL_TRD Sport[OP] like this.
  3. May 22, 2023 at 7:57 AM
    FL_TRD Sport
    Hector
    Port St. Lucie, FL
    True. It doesn't take long to get a little puddle under the truck in this humidity. I'll give that a shot later today, thanks!
    TRDRed likes this.
  4. May 22, 2023 at 8:12 AM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    mine does this all the time when it's humid. it's a regular thing. pretty stupid design. drain isn't clogged either.
    LeakyAC likes this.
  5. May 22, 2023 at 8:19 AM
    FL_TRD Sport
    Hector
    Port St. Lucie, FL
    First time my truck has done it and I've had it for just over 2 years. Hearing this does not make me happy lol.
    dawg1959 likes this.
  6. May 22, 2023 at 8:23 AM
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    Not clogged probably.
    Just condensation accumulating under the dash.its a known issue that toyota ignores
  7. May 22, 2023 at 8:26 AM
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    it happens when i do a lot of short stops getting out and back in the truck. i think it's from constantly opening the doors allowing more humidity into the truck, then condensation occurs.
  8. May 22, 2023 at 8:45 AM
    FL_TRD Sport
    Hector
    Port St. Lucie, FL
    Ugh! I really don't want this being a regular thing. If it's not clogged then it's a design flaw and there's not much that can be done about it. Now I'm almost hoping it's clogged! LOL
  9. May 22, 2023 at 9:04 AM
    FL_TRD Sport
    Hector
    Port St. Lucie, FL
    Not sure if this could be related, but last week I changed out the cabin filter and replaced it with a Fram FreshBreeze filter. Could this have anything to do with it? And yes I pointed the air flow indicator down. Air flow is as good as it was with the OEM filter.
  10. May 22, 2023 at 9:25 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    very good chance if it started the same time.
    Maybe the flow, or restriction, has changed causing this?
    If same timeline, I would go back to OE and see if it helps. Defiantly report back, if it is the aftermarket filter, this could really save someone else some time.
    wise man say: "look first where human was last"
    Good on you for sharing this info,,, many seem leave out info, or even try to hide their changes, as they seem to have some complex, that they couldn't have been the ones to cause it.
    TRDRed likes this.
  11. May 22, 2023 at 9:34 AM
    FL_TRD Sport
    Hector
    Port St. Lucie, FL
    Trust me, when something goes wrong I make myself the first suspect LOL. I'm mechanically impaired and I'm trying to push myself to do some simple stuff and learn. Figured the cabin filter was a no brainer. Apparently not! :)
    TRDRed and Chew[QUOTED] like this.
  12. May 22, 2023 at 9:36 AM
    Chew
    Chewy
    Midwest
    19 TRD OR
    because you and I just want the shit fixed, regardless of who did what!
  13. May 22, 2023 at 9:37 AM
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    i've changed my cabin filter numerous times with different types and it has made no difference in regards to the dripping/condensation. once i roll up the windows and put recirculate mode on it dries everything out in about 20-30 minutes. I found the dripping is worse when i have the air set to the top vents only.
    Barcelona Rahab and LeakyAC like this.
  14. May 22, 2023 at 9:44 AM
    gen2eng
    gen2eng Well-Known Member
    Indiana
    2022 TRD Offroad DC 4x4
    Used to have a home with a humidification system on it with an overflow line to a drain into a slab drain on the interior. If running heavily, seemingly at random, it would backup and result in wet carpeting.
    Root cause was too long of a tube that would plug up with biological "gunk" that I would have to blow out periodically with a compressor. I eventually shortened it up and dumped it through a grossly oversized PVC tube.
    Where I live, mud daubers are a problem if something is left to sit too long. Maybe something similar in your case?
    I don't know enough about the condensate drain on the tacos to know if it's safe to blow pressure backwards through the system, but I know I won't be adding the drain extension that some folks do for fear of compounding the length of the tube and risk room for more gunk to grow.
    Barcelona Rahab, TRDRed and Chew like this.
  15. May 22, 2023 at 9:45 AM
    Chew
    Chewy
    Midwest
    19 TRD OR
    good point, blowing out the drain at home, is bi yearly maintenance for me, as the slow moving water does cause gunk, yet doesn't have enough flow/force to move even the slightest restriction.
    TRDRed and gen2eng[QUOTED] like this.
  16. May 22, 2023 at 9:47 AM
    FL_TRD Sport
    Hector
    Port St. Lucie, FL
    Sounds like my ex wife :anonymous:
    Williston, TexasG and Chew[QUOTED] like this.
  17. May 22, 2023 at 9:55 AM
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    might try another can of kilma cleaner on my next day off.
    edit: going to try this instead
    https://www.lubegard.com/products/evap/
    i parked under a tree for a couple years and i was constantly cleaning out debris from the intake vents and on top of the cabin filter. I'm sure some crap has made it into the system so hopefully this will clean any gunk out that is hindering the flow of water.
    Barcelona Rahab likes this.
  18. May 22, 2023 at 10:48 AM
    Tachi2006
    Tachi2006 Well-Known Member
    Hawaii
    2023 Tacoma, 1990 Landcruiser
    I have cleaned the drain line by taking a shop vac to the discharge hose under truck and vacuming the hose. You will need to modify the vac hose to make a good fairly tight fit (rag or duct tape or whatever you come up with) You will be sucking the condensate hose and pulling any water, skum and debris out and no chance to cause other issues.
    Barcelona Rahab, gen2eng and Chew like this.
  19. May 22, 2023 at 12:05 PM
    Chew
    Chewy
    Midwest
    19 TRD OR
    good point!
    This is a good start for drain lines that are often soft PVC and don't have clamps. If you use compressed air, and have a good blockage, you run the risk of blowing the ends off, or maybe even splitting the hose. Of course some drain lines (like moonroof) can require some mild to major disassembly to replace/fix.
  20. May 22, 2023 at 12:13 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    I don't think the drain line is the problem, or at least not always. I have had water condensate on the air ducts to the two main central ducts in the dash and after a while they drip down from above onto the passenger side carpet and mat. Drain has always worked perfectly fine and yet this still happens. Doesn't make sense except for it to be something else, like the ducts. I have for sure felt the ducts with the radio removed and they were damp on a hot day with the air running through them.
