A/C Condenser fan
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mmatheny, Apr 22, 2011.
  1. Apr 22, 2011 at 2:25 PM
    mmatheny
    mmatheny [OP] Well-Known Member
    Dickinson, Tx
    2017 SR5 DC short bed Magnetic Gray Metallic
    BakFlip MX4
    My Taco A/C just doesn't cool very well when still or moving slowly. Being that the airflow though the condenser is directly related to the engine RPMs, I'm thinking about adding a condenser cooling fan. Any recommedations?
  2. Apr 28, 2011 at 11:33 AM
    mmatheny
    Dickinson, Tx
    BakFlip MX4
    Nothing??
  3. Apr 28, 2011 at 12:47 PM
    mmatheny
    Dickinson, Tx
    BakFlip MX4
    Someone in another forum suggested I check the freon level - is there a site window on these systems, or do I need to depend on pressures?
  4. Apr 28, 2011 at 12:56 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Use gauges.
  5. Apr 28, 2011 at 2:23 PM
    Superx2
    Superx2 Well-Known Member
    Joey
    Iowa
    Yep. Don't guess it, don't put too much in either. You may damage your unit in the long run. I wouldn't do the fan thing. Imo
  6. Apr 28, 2011 at 9:57 PM
    Boost JuNkY
    Boost JuNkY Well-Known Member
    Billy
    Vancouver, BC
    2006 DC SPORT 6MT
    885's, OME Nitros, AP 3" leafs, DTLT's, Magnaflow Exhaust, TRD SS, AFE prodry S, URD Maf Cal, Exedy Clutch, URD TOB, Bhlm, AP winch bumper, Daystar 9" lights, OEM roof rack, Yakima fairing, Bed & rock lights, Sony Sub & Amp, 48" Hi Lift, 4X sliders,
    Its most likely the lack of fan speed. Convert to an electric fan setup. Pretty easy. I did it using a 16" puller fan and a honda thermo fan switch I had lying around with an override switch inside for the a/c on hot days.
    lsocoee likes this.
