A/C Condenser *high side* leak
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SnipesTaco619, Aug 12, 2015.
  1. Aug 12, 2015 at 5:45 AM
    SnipesTaco619
    SnipesTaco619 [OP] Member
    San Diego,CA
    DBL Cab, 6-Speed, 2014
    Snug-Top CamperShell, Custom Bed Carpet Kit/Storage
    Question for all 2nd gens, have any of you replaced a A/C condenser and have the high side hose connection start to leak due to improper seating? Could you/did you use a polyurethane condenser gasket or o-ring? (Low side has a O-ring in hose groove, but not the high side)
  2. Aug 12, 2015 at 6:10 PM
    RobertHyatt
    RobertHyatt You just can't fix stupid...
    Robert
    Birmingham AL
    2007 Tacoma Prerunner SR5
    What is low side and high side on the condensor? The whole thing is "high side" as in high pressure, to force the R134a to condense as air extracts the excessive heat.
    In any case, I am certain both sides should have an o-ring or seal, inlet (compressor side) and outlet (to evaporator). No way metal to metal will seal at those pressures...
  3. Aug 12, 2015 at 6:17 PM
    1rooster
    1rooster TACOMA31750
    Georgia
    2007 Tundra crewmax
    5100's ALL WAY AROUND, 885X COILS, DRIVER SIDE LEAN SPACER, ICON PROGRESSIVE AAL W/O OVERLOAD, 265/75/16 KENDA KLEVER M/T. 1 1/4 SPIDERTRAC WHEEL SPACERS, GEN 1 TRD COLD AIR INTAKE, STOCK MUFFLER WITH CHOPPED TURNDOWN, 5% TINT OVER FACTORY, DEBADGED, TOYOTA RUBBER BED MAT, WEATHERTECH MATS,UWS TOOLBOX, UNDERCOVER SE, LOCKER MOD, REAR BUMPER, PIONEER DOUBLE DIN WITH PARKING BREAK OVER RIDE, CUSTOM OIL CATCH CAN, FULL LED INTERIOR, ARB BUMPER REPLACEMENT. COVERKING SEAT COVERS. MORIMOTO H1 MINI COVERSION WITH MINI GATLIN GUN SHROUDS AND 5000K MORIMOTO BULBS. TRAILER PLUG RELOCTED TO BUMPER. 20 INCH LED LIGHTBAR MOUNTED BEHIND CUSTOM PAINTED GRILL. STUBBY ATNENNA
    When you took it apart do you remember if it had an o ring? Like you said, I would think it would have had one. If it is completely empty your going to have to take it to a hvac professional. ( pretty much any auto shop) and get them to pull a vacuum on it to properly recharge the system .
  4. Aug 12, 2015 at 7:18 PM
    SnipesTaco619
    San Diego,CA
    The low side (bottom hose, into the condenser) is fine and has a oring. The high side (out the condenser and to the Compressor, top hose) has no o-ring, but looks to be a gasket of some sort. There isn't any indication of any grooves to put a o-ring in, but a ring like gasket in a groove on the condenser itself.
    When I removed it, I didn't come across a gasket on the hose. Im not sure if its the condenser I purchased may be a defective...
  5. Aug 12, 2015 at 7:29 PM
    Tretiak30
    Tretiak30 Well-Known Member
    Roman
    Cleveland, Ohio
    THE Ohioan.
    neo-garage.com
    There are two types of seal systems when it comes to AC systems. I work on them everyday... You have your basic o-ring style and like you said a metal/rubber gasket.
  6. Aug 12, 2015 at 7:41 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
  7. Aug 12, 2015 at 9:02 PM
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    Harbor Freight sells a vacuum pump for ac systems.
  8. Aug 13, 2015 at 8:46 AM
    SnipesTaco619
    San Diego,CA
    Awesome thanks guys! Appreciate all of your input!
  9. Aug 13, 2015 at 7:32 PM
    RobertHyatt
    Robert
    Birmingham AL
    That sounds more reasonable. Some use o-rings. Some use various other types of rubber-like material for gaskets. It just needs a really good seal. A typical paper-type gasket won't cut it.
    BTW the harbor freight pumps can be pretty good. My old pump died last year, I bought a two-stage pump from HF and it will pull a sub-50 micron vacuum which is beyond stout. I was afraid it was going to suck the o-rings into the refrigerant lines for a bit. A good set of manifold gauges and you won't have to visit an A/C shop again and pay ultra-high wages or ultra-high prices for R134a which you can find for sub-$10 all day long, and if you order in advance you can find even better deals. I've seen it for sub $10 prices at Home Depot for unknown reasons...
  10. Aug 13, 2015 at 9:15 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    You have to be careful with the box store cans of R134a. Most of it has PAG oil and sealant mixed in, which is great if you are trying to top off grandmas 1987 buick with a slow leak, not so great on a new pump and condenser. Will it blow cold air? Yeah, till the pump squeeks. (I know you know this)
  11. Aug 14, 2015 at 10:02 PM
    RobertHyatt
    Robert
    Birmingham AL
    None I have bought has PAG included. Nor dye or leak sealant. I agree that adding crap to an A/C system is likely going to do more harm than good (although the dye is pretty benign overall). If you replace parts, you need a good manual anyway to tell you how much PAG to add per component replaced. A little too much is not so bad. Too little can be catastrophic.
  12. Aug 15, 2015 at 8:34 AM
    Failure2Comply
    Failure2Comply Old HVACR Tech
    Virginia, USA
    05 Access Off Road TRD/SR5
    The refrigerant leaves the compressor as a high temperature/high pressure vapor. It "Condenses" in the condenser to a "Sub-Cooled" liquid ready to be fed to the metering device where it is flashed to a 80% liquid/20% vapor as it enters the evaporator (further cooling the liquid). It then continues to evaporate to (hopefully) 100% vapor with a 10-12F "SuperHeat" added to the vapor to ensure only vapor enters the compressor. It is a Low Temperature/Low Pressure Vapor at this point. The "Accumulator" is a bandaid added to help assure only vapor enters the compressor where it starts the whole cycle over.
    username likes this.
