A/C Condenser Replace
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SnipesTaco619, Aug 6, 2015.
  1. Aug 6, 2015 at 6:09 AM
    SnipesTaco619
    SnipesTaco619 [OP] Member
    San Diego,CA
    DBL Cab, 6-Speed, 2014
    Snug-Top CamperShell, Custom Bed Carpet Kit/Storage
    Question for any of you guys that replaced a 2nd Gen AC Condenser.
    How much R-134A PAG oil would you suggest to add in a replacement AC Condenser? About a 1/4 cup full? 1/2?
    ***Condenser was made for Tacomas made after 04/2012, FYI
  2. Aug 6, 2015 at 8:23 AM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    5.61 FL OZ of oil and 21.11 OZ of R134a
    Here is the thread from when I replaced mine last time, might help.
    File IFR likes this.
  3. Aug 6, 2015 at 8:34 AM
    SnipesTaco619
    San Diego,CA
    @username Awesome thanks! Ill check it out!
  4. Aug 6, 2015 at 9:15 AM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    It depends on how much you lost. If you pulled a vacuum prior to the exchange and measured how much oil was lost then you can determine how much to replace. If not you have to pull one after the exchange and measure how much you vacuumed out along with guessing if any was lost at any other time. I would caution you about putting too much back in as the cooling effect will be diminished.
  5. Aug 6, 2015 at 11:56 AM
    SnipesTaco619
    San Diego,CA
    @savedone my condenser is punctured, some idiot ran right infront of me. The green oil and refrigerant evacuated itself.
    Good to know thanks.
