A/C drip mod kit….
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by Vorra65, Sep 1, 2021.
  1. Sep 1, 2021 at 9:39 PM
    Vorra65
    Vorra65 [OP] Well-Known Member
    71607730-97BC-40AF-BFAF-FE3BB75B2FF7.jpg I’ve had a couple guys contact me interested in the hose adapter I made to redirect the A/C drip directly to the ground. If you check out the “ what have you done thread” there’s some images of the setup.
    I put together a little kit-
    The adapter (6061 alum.) machined to fit inside stock drip tube-other end machined to accept 1/4 tubing
    24” tubing ( I cut mine at 19-3/8)
    2 mini zip ties
    USA only
    $42 Venmo
    $45 PayPal (sorry, PayPal charges a fee for the $$ transfer)
    Shipped USPS priority mail with tracking number provided.
    I machined in a cavity that allows some packing/ screen as some people were talking about wasps and other bugs being an issue where they live.
    there have been many versions used to accomplish this, this is how I did it
  2. Sep 1, 2021 at 10:05 PM
    RoostrC0gburn
    RoostrC0gburn Well-Known Member
    Oregon
    2017 Super White DCLB TRD Sport 4x4
    this is just for manual transmission, right?
  3. Sep 1, 2021 at 10:15 PM
    Vorra65
    Well not sure how this applies to the M/T. My taco is a 2021 SR5 LB with A/T.
    GaryLaurenLogan likes this.
  4. Sep 2, 2021 at 1:00 AM
    tacokarl
    tacokarl Big Blue
    Karl
    Connecticut
    2008 Pre-Runner SR5 DCLB
    Vorra65, do your thing man! Kit looks top notch, if I hadn't already done this mod i'd be all over it... p.s. between you and me I paid $100 for a silly shift knob :bananadance:
  5. Sep 2, 2021 at 7:30 AM
    Vorra65
    Thanks , appreciate the comment.
    :thumbsup:
  6. Sep 2, 2021 at 10:09 AM
    steele-taco
    steele-taco Well-Known Member
    james
    Jersey shore
    17 TRD OR DCSB white
    Does the adapter reduce the size of the original drain?
    Vorra65[OP] likes this.
  7. Sep 2, 2021 at 10:15 AM
    Vorra65
    Yes, the ID of the OEM drain tube is just shy of 1/2” - the adapter necks down to 1/4” OD and 3/16 “ ID. The large end is machined to 3/8 “ ID
    Drains perfect
    eurowner likes this.
  8. Sep 2, 2021 at 10:29 AM
    steele-taco
    james
    Jersey shore
    How does the adapter actually mount up to the factory drain?
  9. Sep 2, 2021 at 10:36 AM
    Vorra65
    It fits snugly into the factory drain, the machined surface much like a fuel filter has a raised area on the end. Slip it into the drain tube till it stops, put the zip tie on, and repeat the steps for the smaller tubing. In the photos, you can see I routed mine down to the brake line bracket. Then back and down on the outside of the frame between the furthest 2 tabs that hold the splash guard. You could route the hose a number of ways, and before attaching the zip ties- I would recommend routing it a few different ways to see which you like best. I just found this to work best for me.
  10. Sep 2, 2021 at 12:51 PM
    steele-taco
    james
    Jersey shore
    Do you have any pictures of the adapter fitted to the factory drain tube. I can’t quite picture it with the zip tie on your fitting.
  11. Sep 2, 2021 at 12:56 PM
    Vorra65
    I’ve yet to put the zip ties on mine, but here is a picture of the initial fitment before I finished machining the other parts of the 6061. As you can see the aluminum butts up against the factory drain. The zip tie would be added just after the aluminum on both sides. I hope the pics can help you visualize where the zip ties would go. 3846337A-782C-49A8-879E-ECEAD8E1B6D4.jpg
  12. Sep 2, 2021 at 1:08 PM
    chuam
    chuam Well-Known Member
    Marcus
    San Diego
    2017 Tacoma SR5 DCSB 4x4
    Icon Stage 3 - 2.5 & UCAs front, Icon 2.0 rear Icon RTX Stage 2 leafs Icon 700lb springs RSI Smartcap Evo Sport KDMax Pro tune BAMF Hybrid front bumper Warn VR EVO 10s winch ARB Rear Locker Revolution 5.29 regear RCI Engine Skid RCI Trans skid RCI Transfer case skid RCI Diff Skid RCI Cat guards RCI Rock sliders RCI roof rack R4T LCA Skids DRT Fabrication Hitch Skid Exhaust reroute ARB Dual Compressor w/ Slee Mount OR Black Fenders Diode Dynamics SS3 Pro fog lights Rigid D-SS Pro Ditch lights Rigid SR Amber PRO Edition 30” light bar Rigid SR-Q floods A/C drain mod Differential Breather Mod Supralee Traction Board mount Liftd Gas cap holder Taco Garage DMM 2.0 Total Chaos bed stiffeners TRD SEMA Pro 17" wheels Falken Wildpeaks 275/70r17 TRD Pro Grill Gecko shell lighting Ecological Bumper shells Fumoto valve Toyota aluminum oil filter cap DesertDoesit Seat Jackers Waterport Day Tank - Rago Fab bed mount Yakima Double Haul OVS 270 Awning Wet Okole seat covers Overland Equipped/Blueseas Bracket/fusebox Toyota OEM tailgate lock Rogue Offroad poly body mount bushings ZPrecision cup holders H9 headlight bulb upgrade Lambtek innovations winch switch
    I'd totally buy this.
  13. Sep 2, 2021 at 1:42 PM
    OG_Tacoma
    OG_Tacoma Well-Known Member
    Transmission shouldn't matter right? Would this work just fine on M/T?
    corgimas and Vorra65[QUOTED][OP] like this.
  14. Sep 2, 2021 at 2:24 PM
    Vorra65
    If your M/T truck has the drip tube coming out of the passenger side firewall- then yes it would absolutely work. Just can’t imagine Toyota changing the cab just for the drivetrain.
  15. Sep 2, 2021 at 2:47 PM
    chuam
    Marcus
    San Diego
    @Vorra65 let me know if you got the PM
  16. Sep 2, 2021 at 3:00 PM
    Vorra65
    I just watched a video, of a M/T taco- the drip hose appears to be in the exact same location both A/T as well as M/T. :thumbsup:
  17. Sep 2, 2021 at 3:02 PM
    Vorra65
    Got it,
  18. Sep 2, 2021 at 3:03 PM
    Vorra65
  19. Sep 2, 2021 at 4:38 PM
    HelloFelix
    HelloFelix Well-Known Member
    Felix
    Las Vegas
    2017 MGM 4x4 OR Tacoma
    Pm sent
  20. Sep 2, 2021 at 4:43 PM
    Vorra65
    Got it and response sent
