A/C evaporator broken, quoted $1,800 to fix
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mozart, Jun 15, 2022.
  1. Jun 16, 2022 at 8:40 AM
    ShirtTucker
    ShirtTucker Taco Tip Line: 248-434-5508
    2017 V6 Sport AC MT
    Lots-o-stuff
    RX1cobra, shakerhood and Chew like this.
  2. Jun 16, 2022 at 9:14 AM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    I’m curious too, 2019 here.
  3. Jun 16, 2022 at 9:50 AM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    I don't think it ever was. The TSB never mentions it and there have been other complaints of condensation dripping from it. Never have I seen a mention of a redesign for it.
    Sucks for OP but I think this is just shit luck. Doesn't seem to be a common failure.
  4. Jun 16, 2022 at 10:01 AM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Did you post in the wrong thread by chance? I'm a bit boggled with what a 2004 Ford has to do with anything here.
  5. Jun 16, 2022 at 8:54 PM
    Mozart
    Mozart [OP] Well-Known Member
    Cortland NY
    2018 ACLB SR5 4x4 V6
    32” Tires, BPF Front Recovery
    I’m not sure. The service adviser said the part was a new revision. It’s even written on the estimate that way.
    perhaps that was a lie to get me to have them do the work rather than ordering an aftermarket evap core and hiring a private mechanic? “Ours is a NEW and IMPROVED part!” ?? Who knows.
    I have a call into Toyota about this, but I missed their callback today because I went out to get the mail. They called during a 45 second window when I didn’t have my phone, I swear to God.
  6. Jun 16, 2022 at 9:14 PM
    bcmbcmbcm
    bcmbcmbcm Well-Known Member
    Brett
    22 Barcelona Red TRDOR 6MT worth the wait !! Hang in there !!
    Sorry OP this sucks. Regardless of who pays, if you can find a dedicated Auto AC shop that may be best. They are hard to find though. They are used to taking interiors apart. Next best, but more complicated, is going to an upholstery shop and have them remove the dash, then bring to a repair shop for the EVAP core (or use a mobile mechanic), and reassemble. I did this with a Mustang years ago for a heater core. I wanted it taken apart and put together with care by folks who know interiors, not mechanics.
    Kev250R and Canadian Caber like this.
  7. Jun 16, 2022 at 9:51 PM
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    The evaporator in my 2nd Gen (2010) sprung leak in 2017 at like 75k miles. Thankfully, the A/C never outright failed. It blew ice cold out of the driver's side, but warm out of the passenger side; My old mechanic charged it twice but could not find the leak. Having lost patience, I brought it to the local dealer in August 2018 when it got progressively worse over the course of a weekend (but still didn't fail entirely); They found it to be about a pound low on refrigerant and charged it up, along with UV dye. I brought it back in September and thanks to the UV dye they traced it to the evap core. I wanted my A/C fixed and the dealer had a free loaner vehicle, so I paid almost $1,600 to get the evap core replaced; The system had to be evacuated and disassembled when they replaced my frame in November 2021, but I have no had any problems with the A/C in my truck since August 2018.
    My truck uses R134a, but I'm assuming that yours uses R1234yf?
    Kev250R and shakerhood like this.
  8. Jun 16, 2022 at 10:31 PM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    OP, after rereading your post, when you say it is 'blowing warm" is that all the time or just some of the time? If it is just some of the time, you likely don't 'need' a new evaporator. There have been complaints of poor cooling on some trucks (I think out west in hot temps) at low speeds and that is where the aux fan (TSB) was installed. Although I really don't understand the issue because I have a 18 and it cools fine under all conditions. It would seem to be a charge issue or fan clutch issue.
  9. Jun 17, 2022 at 5:32 AM
    Sungod
    Sungod Well-Known Member
    St Augustine
    Evaps have become so thin and cheaply made these days I wouldn't be shocked at having one leak. Toyota definitely didn't make them serviceable. $1800 is about right for dealer pricing. You could probably get it for half that at a local A/C shop. I would however confirm that it is the evap leaking. That is done with dye and a camera. If it leaking your only option is to replace. The TSB has nothing to do with thin metal or poor welds.
    davidstacoma likes this.
  10. Jun 19, 2022 at 2:36 PM
    Mozart
    Cortland NY
    I don’t know what method they used to determine it was the evap core. I don’t think they did anything with dye but I dont know for sure.
    I’m going to try to reach Toyota corporate tomorrow and if they decide not to help me, I’ll probably just pay for a recharge.
    I have a relative who had the engine in her Ford suv seize, because the head gasket failed and it mixed lots of coolant into the oil during a 3.5 hour trip. It was VERY out of warranty, but the dealership called Ford on her behalf and got her a free replacement engine because those head gaskets were a known issue. She didn’t call anyone. Fords may be unreliable garbage but that level of loyalty to customers blew me away.
  11. Jul 6, 2022 at 10:37 PM
    Mozart
    Cortland NY
    SITREP: Toyota is covering it 100%. That is awesome of them. I am a lifetime customer now.
  12. Jul 6, 2022 at 10:43 PM
    PennSilverTaco
    Charlie
    Had to have the evaporator in my 2010 replaced back in 2018; Cost just under $1,600 at the dealer...
    Mozart[OP] and shakerhood like this.
  13. Jul 7, 2022 at 7:53 PM
    Mozart
    Cortland NY
    My sisters’ Audi Q5 and my brother in laws’ Honda Civic both have A/C down right now, and both are because of an evap core failure! Go figure. Makes me wonder if there’s only 2-3 companies that make these things and lots of car companies source the same ones . . . .
  14. Jul 7, 2022 at 7:58 PM
    PennSilverTaco
    Charlie
    Luckily, my A/C never outright failed; It always blew ice cold out of the two driver's side vents, sorta cool out of the middle right vent, and warm out of the far right vent. It took over a year and a half and three recharges before the leak was found...
    shakerhood likes this.
  15. Jul 7, 2022 at 8:16 PM
    #35
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    Sure is good advise. Maybe I'll use it someday. Good Luck OP and i agree yours must have had something buggy if it turns out to need that job.
  16. Jul 7, 2022 at 8:21 PM
    #36
    Bishop84
    Bishop84 Well-Known Member
    Next bit of advice. It's a bear to do the evap core, so do the tech a favor and clean out the front of the truck, remove all accessories.
    Next right as you drop it off, take pictures of the dash and steering wheel. Just incase they scratch anything.
  17. Jul 7, 2022 at 8:22 PM
    #37
    PennSilverTaco
    Charlie
    My truck was over 7 years old and had like 75K miles when the problem manifested itself in June 2017; I wouldn't have noticed it if I hadn't reached across the cab on a humid day to unlock the door or something, and realized that air coming out of the far right vent wasn't cold.
  18. Jul 7, 2022 at 8:27 PM
    #38
    Mozart
    Cortland NY
    Good advice, thank you. Yeah I had planned to empty out the glove box and center console, and take pictures and video of everything working properly just in case something is broken during disassembly.
  19. Jul 26, 2022 at 2:34 PM
    #39
    Mozart
    Cortland NY
    Got the truck back. Everything looks and functions great. No issues with damage to the dash or loose / rattly interior trim. Drove it about 75 miles today. It all feels and works as good as the day I dropped it off. I am very thankful to Toyota USA and to Maguire Toyota in Ithaca.
    If anyone else has a similar issue with their A/C, turns out the exact TSB is 0004-22, which calls to remove / replace the HVAC Evaporator sub assembly (which is BURIED in the dash).
    https://static.nhtsa.gov/odi/tsbs/2022/MC-10207964-9999.pdf
  20. Jul 27, 2022 at 9:29 AM
    #40
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    probably going to have to get this on my truck. i actually have a leak coming from a seam from under the evaporator housing box as well as the whistling noise.
