a/c evaporator not draining
Discussion in 'New Members' started by mueller, May 31, 2013.
  1. May 31, 2013 at 11:43 PM
    mueller
    mueller [OP] Member
    joe
    riverside, ca
    blue 08 4dr prerunner sr5
    My a/c evapoator is not draining and causing a foul
    odor, a wet towel kinda smell. Any suggestions?
  2. Jun 1, 2013 at 12:06 AM
    medic2230
    Murph
    Bama! Roll Tide
    Your drain is probably clogged.
  3. Jun 1, 2013 at 12:07 AM
    169.254.255.201 Well-Known Member
    Interwebs
    i had the same issue awhile ago.
    Had to go under truck, directly underneath where passenger feet could extend to and blow out the copper looking downspout using a air compressor
  4. Jun 1, 2013 at 12:09 AM
    medic2230
    Murph
    Bama! Roll Tide
  5. Jun 1, 2013 at 12:14 AM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Remove the "black box" if you have a 5-lug, or the mud flap if you have a Prerunner/4x4.
    The drain will be under there. Clean the crap out.
