A/C FAN ISSUE
Discussion in '2nd Gen. Tacomas (2005-2015)' started by qbnpapi, Oct 16, 2011.
  1. Oct 16, 2011 at 6:31 PM
    qbnpapi
    qbnpapi [OP] Member
    Papi
    FELLOW TACO LOVERS!!!
    Looking for a little guidance. My a/c has stopped working. Recirculation button still lights up but not the a/c. The fan is not working in any speed. I have checked the fuses both IG1 AND IG2 10A fuses as well as the 10A fuse in the engine compartment. All are still good. I read something about the HVAC resistor going bad, but what i have read is that it works for some in some speeds. I have NO speeds. Does any one know the value of the resistor to check it, so I can rule that out before I spend the $ on it? ANy help would be much appreciated.
  2. Oct 16, 2011 at 10:44 PM
    808brian
    808brian Well-Known Member
    Brian
    Maui
    Black z
    Take it back
  3. Oct 16, 2011 at 10:51 PM
    I Liquid I
    I Liquid I Well-Known Member
    Puerto Rico
    06 BSP Double Cab Long Bed
    Too many mods to list
    Below the glove box is the blower. Give it a tap and see if the A/C comes on. I had to change mine about 2 years ago, but didn't. It might not start once or twice in a month until I give it a light tap. It has worked for me, might work for you.
    Note: I have kept this unit that has a problem because apart from that it emits no sounds like many here have experienced. I figure I would rather take a rubber mallet to it once or twice a month than be annoyed with a weird sound.
  4. Oct 18, 2011 at 4:38 PM
    qbnpapi
    qbnpapi [OP] Member
    Papi
    does it matter if the light doesn't come on the a/c button? is that an indication that the fan is going bad?
  5. Oct 18, 2011 at 4:38 PM
    qbnpapi
    qbnpapi [OP] Member
    Papi
    take whatt back...shoootz!
  6. Feb 6, 2013 at 8:57 PM
    takao96753
    takao96753 Member
    mike
    KIHEI
    2010 Reg Cab 4wd
    Just checking if OP had fixed this issue and what it was I currently having the same issue.
  7. Feb 6, 2013 at 9:03 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    This vvvvvvvvvvv
    Was the last post the OP made on this forum.
