A/C & Heater Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mr.ernst, Mar 2, 2010.
  1. Mar 2, 2010 at 6:43 PM
    mr.ernst
    mr.ernst [OP] Well-Known Member
    Baton Rouge, LA
    2009 Prerunner bone stock
    I tried to search around and find some info but came up blank. I'm not even sure what the button/switch is called but it's basically what you'd use to recycle the cabin air when using the heat or a/c. Anyways I turn mine on every time I get in the truck, and every time within 3 minutes it resets/turns itself off. I can turn it back on and 3 minutes later, it's back off.
    It doesn't matter what vent setting or air temperature I have it on, or whether I have the A/C button on, right around 3 minutes it turns itself off. I pulled my radio out a few months back, but made sure everything went back in and everything was plugged in properly. Plus it doesn't make sense that it would be a bad connection, because it comes on every time I push the button, it just turns itself off 3 minutes later.
    Anybody else experience this?
  2. Mar 2, 2010 at 6:49 PM
    doubletaco
    doubletaco Well-Known Member
    Magnolia
    16 Quicksand TRD O/R 4x4
    TRD FJ Wheels, LED Fog lights
    You have to hold it down for a few seconds it's in the owners manual.
  3. Mar 2, 2010 at 6:50 PM
    mr.ernst
    Baton Rouge, LA
    No sh*t. I should probably get off of here sometime and take a look at that thing. Thanks, I'll test that out in the morning.
  4. Mar 2, 2010 at 6:51 PM
    SlurpeeBlueMetallic
    SlurpeeBlueMetallic FFFFFFUUUUUUUUUUUUUUU...
    Yep... excerpt from the owner's manual:
    If the ambient temperature drops while using the recirculated air mode
    The air intake mode automatically changes from recirculated air mode to outside air mode after a few minutes.
    To cancel this function:
    Press and hold for longer than 2 seconds. To reactivate this function:
    Turn the engine switch to the LOCK or ACC position.
    This sound like what you're experiencing?
  5. Mar 2, 2010 at 6:54 PM
    mr.ernst
    Baton Rouge, LA
    That's gotta be it. I hadn't paid it any attention before it got so cold and just noticed it's been doing it lately. Tonight I finally decided to time it, but yeah that's gotta be it. You guys are awesome.
  6. Mar 2, 2010 at 7:25 PM
    doubletaco
    Magnolia
    I thought I was going crazy until I read the manufacturers opinion on how to operate the vehicle.
  7. Mar 2, 2010 at 7:26 PM
    mr.ernst
    Baton Rouge, LA
    How do you only have 9 posts and yet so much wisdom :confused: Just kidding man, thanks again.
  8. Mar 2, 2010 at 7:29 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    I did not know that! :eek:
  9. Mar 2, 2010 at 10:10 PM
    doubletaco
    Magnolia
    Been a Toyota owner for over 25 years now, plus it helps being a mechanic.
