a/c help needed.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Silver96, Oct 17, 2009.
  1. Oct 17, 2009 at 1:24 PM
    Silver96
    Silver96 [OP] Active Member
    I have changed the condensor and dryer, checked the lines, and my system still has a leak. After a full charge of 134a it blows cold air for about 30 minutes to an hour and then quits blowing cold air. I've had dye put into the system and had it sniffed but I haven't been able to find anything. I really need some help. Thank you.
  2. Oct 17, 2009 at 6:06 PM
    slickyd
    slickyd Well-Known Member
    David
    Talladega, AL
    03 PreRunner SR5
    has it gotten better at holding the 134a or is it worst now since you changed those other parts?
  3. Oct 17, 2009 at 9:23 PM
    trailinTaco
    trailinTaco Well-Known Member
    Bel Air, MD
    2000 Tacoma SR5 TRD 3.4L 4x4
    3 inch suspension lift, 33 inch bfgoodrich mud terrain tires, toytech diff drop, Procomp alloy wheels, hella fog lights, black projector headlights with 8000k HID's, blacked out tail lights, two 12 inch subs, 20% tint, pioneer head unit and speakers
    if you cant find it then its probably the evaporator which is behind the dash. check for dye coming out of the drain tube for the evaporator or where ever the ac drips.
  4. Oct 19, 2009 at 7:38 AM
    Silver96
    It's holding the 134 in the system for about the same amount of time. TrailinTaco, I haven't checked the outlet tube yet.
  5. Oct 19, 2009 at 8:34 AM
    2toys
    2toys Well-Known Member
    Los Angeles
    01 Red Hot Double Taco
    If it's that large a leak, you should be able to HEAR the gas leaking out! drive to a quiet spot, add some charge and follow your ear...
  6. Oct 19, 2009 at 9:55 AM
    Silver96
    I've tried listening for a leak but I can't hear anything. I was told that if it was the evaporator the evidence of a leak would be contained inside the evaporator/housing. Maybe that's the reason the sniffer/UV hasn't picked it up?
