A/C help
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacosuprem, Jun 5, 2010.
  1. Jun 5, 2010 at 7:21 PM
    tacosuprem
    tacosuprem [OP] Well-Known Member
    Florida
    4x4
    hello everyone. I just bought a 1997 toyota tacoma. It has the 2.7 litre 4 cly ,5 speed ,4X4 ,reg cab. It also has 209,000 miles. Runs great!
    The A/c on the tacoma works, but it works only for a few days. i charged the system and it gets ice cold then looses its charge. i tried the dye test and did not see any dye anywhere. i used a black light, but nothing. has anyone else have this type of problem? i saw an a/c leak repair kit at walmart but didnt want to use it till i got more info. I love the truck! i just wish i can keep the a/c working more than 2-3 days. What do you guys think? i cant afford going to an a/c shop. Help florida is hot as he11. :confused::confused:
  2. Jun 5, 2010 at 7:41 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    If you don't see any leaks in the engine compartment it's possible that you have a leak in the evaporator core. Did you try shining the black light through your a/c vents or around the evap drain tube? The walmart repair kit is only a band-aid and won't fix your problem. If worse comes to worse I would take it to a mechanic you trust and have them look at it.
  3. Jun 6, 2010 at 11:02 AM
    tacosuprem
    Florida
    4x4
    yes i did check the vents and the evap drain tube. does the evap tube suppose to have cool air blowing out of it?
  4. Jun 6, 2010 at 11:05 AM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    He means the actual evaporator coil. It is possible that you have a leak there. Also check your condenser coil as well. The UV leak check method isn't always the best way to locate a leak- you may have some hairline cracks in one or more of the rubber hoses that make up your line set that you wouldn't be able to see with the dye.
    Also know that introducing the dye into your system decreases it's efficiency. :/
  5. Jun 6, 2010 at 1:51 PM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    same truck as mee!!!!! haha but my a/c compressor needs to be replace i have the same problem as you. no leaks and the system holds pressure but a/c only works for like a day.
  6. Jun 6, 2010 at 1:59 PM
    Maintenance Man
    Maintenance Man Well-Known Member
    Justin
    Atlanta, Ga
    05 Tacoma Pre-runner SR5 2.7L
    Leer camper shell; afe stage ll intake; 265's bridgestone dueler tires; rockford's power series 6.5's; tint on all windows; semi de-badged; weathertech digitial mats; grillcraft grill; blacked out headlights with eyelids; blacked out badges; and more to come.
    Try good ole soap and water on all visible A/C lines, if no bubbles, get a quote from a mech. I work on A/C's for homes, you just can't beat soap and water!
  7. Jun 6, 2010 at 2:02 PM
    Maintenance Man
    Justin
    Atlanta, Ga
    Also, if you lose charge and can get your hands on some nitrogen, you can put around 90 p.s.i. of nitrogen in the system and sometimes you can hear the leak with the higher pressure of nitrogen. Nitrogen is safe, JUST DONT OVERCHARGE!
  8. Jun 6, 2010 at 2:57 PM
    NickJ*97756
    NickJ*97756 Well-Known Member
    Nick
    La Grande OR
    95 Red Ext. Cab
    Black Ultra Type 175 Rogue wheels, 33x12.50's, exhaust, sony deck,JL tweeters, hella 500ff's, painted rear bumper, brush guard, tail lights, kc's, custom tube bumper,5100's w/trd springs, toytec aal, custom tire carrier
    I had this same problem but i took it to a mechanic and it ended up being a leak in a hose in the air box, behing the glove box
  9. Jul 24, 2011 at 12:19 PM
    hc243102
    hc243102 Active Member
    ohio
    97 tacoma
    i got the same exact truck, same problem. did you ever find out what was up?
  10. Jul 27, 2011 at 1:42 PM
    Warhorse
    Warhorse New Member
    Lance
    Lorena, Tx
    2000 Tacoma 4x4 TRD
    3" lift
    same problem here, I lose charge in about 5 minutes, and Im getting a smell through my vents does anyone have advice for pulling the evap coil. oh by the way I read that stop leak makes all rubber components swell in a attempt to seal the leak so that cant be good.
  11. Jul 28, 2011 at 3:34 AM
    tacosuprem
    Florida
    4x4
    Hey guys,
    I did find the problem. I had a pinhole leak on the 1/2 aluminum pipe coming off the evaporator coil. I just used a piece of rubber like from a hose and put a pipe clamp on it. It has worked perfect. No leaks yet after a year.
