A/C Idler Pulley tension bolt size??
Discussion in '1st Gen. Tacomas (1995-2004)' started by RacerP, Jun 17, 2017.
  1. Jun 17, 2017 at 3:22 PM
    RacerP
    RacerP [OP] Well-Known Member
    Chicago
    2003 4x4
    7th Injector kit, Trans Cooler, Donohoe c/o's, Billy's in the rear, FJ Cruiser Trail Team SE wheels.
    Anyone know what size the idler pulley tension bolt is??
    Length, size and pitch?
    Got to replace mine
  2. Jun 17, 2017 at 7:33 PM
    RacerP
    Chicago
    2003 4x4
    Already figured it out...8mm x 80mm x1.25
  3. Jun 18, 2017 at 3:16 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Good luck finding that any place but your dealer.
    It needs to be threaded the whole length.
    Maybe your luck will be better then mine
  4. Jun 28, 2017 at 12:19 PM
    RacerP
    Chicago
    2003 4x4
    I was able to knock my shaft out(the sleeve was frozen), put the whole assembly in the vice and used heat and vice grips to remove the old, bent and broken one. Cut it short with a angle grinder first, wanted the cleanest threads so as to not destroy it.
    Found an 8 x 70mm x 1.25 flange bolt at my local hardware store, works for me
  5. Jun 28, 2017 at 1:59 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Glad you found a bolt close at hand no one but the dealer had any thing that would work
