A/C issue… I’m stumped
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacogeorge17, Aug 19, 2023.
  1. Aug 19, 2023 at 2:25 PM
    Tacogeorge17
    Tacogeorge17 [OP] Well-Known Member
    George
    Socal
    2017 black Tacoma TRD OR manual
    Ok so I have a 2017 Trd OR 4x4. My A/C stopped working randomly. I checked the relays and all related fuses and they are good. The compressor is good, the Freon is full and at the correct psi. The fans blow air great I even bought a brand new switch panel from Toyota. Here is the weird part, the A/C blows ice cold air only after I wash my truck:confused:
    HELP!!!!!!!
  2. Aug 19, 2023 at 2:38 PM
    Clearwater Bill
    Billy
    Largo Florida
    Did you check refrigerant with a gauge set or just a parts house low side gauge?
    Define 'stopped working ramdomly' with more specifics.
    Why did you buy a new switch panel?
    Is your condenser clogged with junk (related to the after I wash it comment)
    Chew likes this.
  3. Aug 19, 2023 at 2:58 PM
    Tacogeorge17
    George
    Socal
    i didn’t use it for about 2 weeks when I went to turn it on it didn’t work. It was checked by a buddy of mine with all the equipment. He also checked the relays and fuses. My condenser isn’t clogged as I don’t go in mud and after I hit any trails the truck gets a good wash. I bought a new switch panel because I had credit with the dealership so used it thinking it might be the switch’s.
    I have tried using it and it blows air but doesn’t get cold at all. I wash my truck on Friday after I get off work and after each time the A/C blows ice cold air and stops being cold about 30-45 minutes later it’s a 30-45 minute drive home from where I work and wash my truck.
  4. Aug 19, 2023 at 3:20 PM
    Clearwater Bill
    Billy
    Largo Florida
    Is there a bit of fog or smoke looking discharge at the vents right before the cool stops?
    When the cool stops does the vent output reduce in volumn even though the blower still sounds the same?
    joba27n likes this.
  5. Aug 19, 2023 at 3:20 PM
    NorrinRadd
    NorrinRadd Well-Known Member
    WA
    2019 Sport, access cab, MT, Eibach 2.0 stage 2, tow, silver.
    Just tossing my hat in the ring since I'm bored.
    Perhaps check the air intake outside at the base of the windshield, if it is blocked with crap or a dead mouse there will be less airflow which means less air blowing across the condenser to vaporize the refrigerant which means it will start out blowing cold and then after 15-20'ish minutes it will slowly start getting a bit less cold until finally there is no vaporization and thus only outside air temperature will be blowing in. Washing the vehicle may flush just enough of an opening in the ducts to allow more air in and after the crap in there dries out they start to clog back up. Maybe use a wire hanger and *carefully* poke around from the outside, making sure you do not puncture the ducting.
    But this is just a guess, of course. YMMV.
  6. Aug 19, 2023 at 3:23 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Did you ever have the AC recall done?
    https://static.nhtsa.gov/odi/tsbs/2020/MC-10181775-9999.pdf
    JFriday1 likes this.
  7. Aug 19, 2023 at 4:06 PM
    Tacogeorge17
    George
    Socal
    Volume is still the same when the cool stops. No there is no vapor or fog when the cools stops.
  8. Aug 19, 2023 at 4:47 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    When the cool stops is the AC compressor still turning or is the clutch in the freewheel mode?
  9. Aug 19, 2023 at 5:15 PM
    Tacogeorge17
    George
    Socal
    I haven’t checked that but I will when I wash it again lol.
    RustyGreen[QUOTED] likes this.
  10. Aug 20, 2023 at 7:16 AM
    MadJacks
    MadJacks Well-Known Member
    Justin
    Edmonton, Alberta
    2020 TRD Sport MT
    Do you wash it indoors? Perhaps it's a humidity/sensor issue.
  11. Aug 20, 2023 at 7:23 AM
    TacoNonspecialist
    TacoNonspecialist Well-Known Member
    Noblesville, Indiana
    17 trd sport MGM DCLB 4x4 wtftacosōs
    Driver mod, KDmax, eibach, wheelers, morimoto, and ricer pro grille
    Hook a scanner to it. B1422 code probably exists in the AC amplifier.
    Otherwise, start the truck and spray the condenser with a garden hose and see if cooling stays consistent.
    If everything is working, low side is sweating, high side warm/hot and you're still not cooling, you probably have a blend door issue. Have you attempted a hvac calibration by chance?
    Chew likes this.
  12. Aug 23, 2023 at 6:45 PM
    Tacogeorge17
    George
    Socal
    I will try a scanner when I get into work tomorrow. I have not done an hvac calibration.
    it rained on Sunday and the A/C blew super cold air lol
    LeakyAC likes this.
  13. Aug 23, 2023 at 7:31 PM
    TacoSupremo19
    TacoSupremo19 Well-Known Member
    NJ
    2019 Black Tacoma TRD SPort DCSB
    Brushed Copper Blaze 10 Rims | 265 70 17 Toyo Open Country A/T III tires | Bilstein 5100 w/ Eibach Coils 2.5" lift | Blackhawk UCAs | ICON Rear 3 AAL |TRD Skid Plate | TRD CAI | OEM Rear Bed Lighting | OEM rear Tailgate lock | RC Bed Molle Racks | Custom Blacked out OEM LED Headlights | MESO V4 Mirror Turnsignals | MESO Interior trim blackout | TG DMM dash mount | TRD Shift Knob | OEM SR5 interior door handles | Upgraded Stereo including Alpine 700W Amp Alpine Type R Components & Hertz speakers 12" Sub | Custom Clazzio Seat covers | Mobtown Sliders | Front Camera
    Need to see if the clutch on the AC compressor is engaged when the AC cuts out. That will allow you to further isolate the problem. The wider rubber low pressure hose near the firewall should also be pretty cold. Could be a bad compressor, refrigerant level, pressure switch, a damper door, even a heater valve. Less likely is the actual controls though. Find out if that clutch is engaged and get back to us.
  14. Aug 23, 2023 at 7:52 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    OOOO! I know this one!
    So on your compressor there is a ground wire, its on the top of the compressor and goes behind the clutch. This wire is not protected at all and will corrode, when it does the compressor will not ground and it causes it to not kick on. When you wash your truck, the water gets into that wire and is just enough to complete the circuit.
    The fix toyota did for me was to replace the compressor, but if you cut that ground wire back enough to get clean copper, you can solder on a new wire and ground it. After you replace it, smother it in dielectric grease.
    This is the ground wire
  15. Aug 24, 2023 at 1:16 AM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    Hold the auto and recirc/fresh air buttons. At the same time and while holding switch the ignition to the on position and it will first do a bulb check then it will display hvac codes. 00 is the all clear and anything else is an issue. Without personally reading the gauges myself it's hard to say but I would guess it's a txv valve issue but you should first off see if the compressor is running still when the air warms up.
  16. Aug 24, 2023 at 10:01 AM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    what if you don't have the "auto" button?
  17. Aug 24, 2023 at 1:07 PM
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    My 2016 started blowing slightly warmer thru passenger side front vents than via the driver's side front vents about 2 months ago when the heatwaves hit my area.
    A/C performance when its really hot outside with the truck A/C in the non-recirculate mode also started to degrade some.
    They could not identify an obvious refrigerant leak. So they added dye to the refrigerant and charged up the system and told me to use the truck normally and come back when the A/C performance starts to deteriorate once again.
    This is the first time in the truck's life (2016 build with 72k miles) that the A/C system has been touched. They told me it could take 1 day or 1 year for any type of leak to manifest itself, all depends on the size and location of this would-be leak.
    To you A/C and HVAC nerds....does this sound like legit info?
  18. Aug 24, 2023 at 1:20 PM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    OBD port is the only option then.
    LeakyAC likes this.
  19. Aug 24, 2023 at 1:34 PM
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    yea, that's pretty standard. mine still blows cold but not as cold as when new. i need to get it charged up. my a/c gets used a ton. i do deliveries so i'm constantly getting out and having to crank the a/c to cool down.
    LeakyAC[QUOTED] likes this.
  20. Aug 24, 2023 at 1:37 PM
    dangeroso
    dangeroso Just float along and fill your lungs
    Jon
    Dallas, TX
    2018 Tacoma TRD Sport 4x4
    Interesting! I was thinking electrical connection when I was reading about car wash and rain causing it to start working temporarily.
    Chew likes this.
