a/c issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nb_tacoma, Jul 3, 2011.
  1. Jul 3, 2011 at 2:52 PM
    nb_tacoma
    nb_tacoma [OP] Well-Known Member
    nick
    Thunder Bay, ON
    2006 SR5 access cab 4x4
    2.5 inch toytec lift /w rear block 255/85/16 cooper discoverer st's Westin light bar with 2 hella 500's Satoshi grille mod BHLM bumper valence painted with rocker guard relocated the horns tail gate anti-theft mod added a trailer hitch relocated 7 pin in bumper rear diff breather mod Magnaflow muffler kenwood KDC-X895 deck
    so i went to turn on my a/c for the first since about early last fall
    and it started off warm, so i gave it a few min to try and run and cool down. ran for about 15 - 20 min and nothing, just blows warm air
    any thoughts or ideas?
    thanks -Nick
  2. Jul 3, 2011 at 3:11 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    You have a leak. Time to run some dye through it.
  3. Jul 3, 2011 at 3:17 PM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    No freon?
  4. Jul 3, 2011 at 5:32 PM
    t_e
    t_e Well-Known Member
    Erik
    miami,fl
    see if your compressor kicks on first before you go start looking for leaks.
  5. Jul 3, 2011 at 5:35 PM
    JKD
    JKD Well-Known Member
    Check fuses first.
  6. Jul 3, 2011 at 5:40 PM
    phatdrew
    phatdrew Well-Known Member
    drew
    dover, de
    2" lift, 17" pro comp wheels, 285x70x17 micky t's, billet grill
    I used to have a similar problem on a old mercury of mine. The compressor clutch would stick and I'd have to take a hammer and tap it a few times to get it running. Like the guy before said, check the compressor and make sure it's engaging. Then check for leaks and then have it charged. What year is your pick up? Can't tell since in on my phone.
  7. Jul 3, 2011 at 5:45 PM
    acmair
    acmair Well-Known Member
    Andrew
    '10 BSP PreRunner Dbl Cab Short Bed SR5
    I have a similar problem on a 96 Lumina. Check and make sure the compressor clutch works, because sometimes with low freon, there isn't enough pressure to push the clutch. Otherwise, check for a leak using some freon with dye. We connected the clutch directly through a switch on the dash to have manual control and that doesn't do it either. So, fill up with freon, it should work. If after a few days you lose cooling again, you have a leak. Hope it helps.
  8. Jul 3, 2011 at 5:51 PM
    shane100700
    shane100700 Bed, Bath & Beyond Crawler
    Montana
    2019 DCSB, OR
    Rocket Boosters
    Freon is'nt that expensive. If none of your fuses are blown go to an auto parts store. If they do it for free, have them run your codes and see if an error comes up. If no codes, try charging it. If it works and keeps working, the freon was just low. If it works temp and gets warm again, then you have a leak. The $30-40 it would cost for the can is still cheaper then taking it to a mechanic. Unless you have a buddy that is a mechanic, then buy him a 6-pack and have him check it out!
  9. Jul 3, 2011 at 5:54 PM
    nb_tacoma
    nick
    Thunder Bay, ON
    its a 2006 Tacoma access cab
  10. Jul 3, 2011 at 10:04 PM
    Taco11
    Taco11 Well-Known Member
    Seattle WA
    In order to get this fixed properly and without doing damage to the compressor, you must get it fixed at a shop that has an A/C machine. If the compressor does not kick on, its most likely because of low charge. There is a switch in the system that shuts off the compressor if it is too low on charge as that can cause damage to the compressor. Obviously if the system is low there is a leak somewhere. That will need to be fixed. To fix the leak you must open the system which requires removing all the freon first. After it has been fixed the system must be put into a deep vacuum to remove all the air that has been introduced into the system. Then charged to the correct level.
    Trust me.. you don't want to try this yourself and end up destroying your compressor.
