A/C Issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by undertow519, Jun 25, 2017.
  1. Jun 25, 2017 at 9:23 PM
    undertow519
    undertow519 [OP] New Member
    JC
    2008 Tacoma
    Red, crew cab, TRD
    Hey all - first time poster. I've got a 2008 Tacoma TRD Crew Cab 2x4. The A/C problem I'm having is, sometimes it blows and sometimes it doesn't. What seems to happen is, I'll hit a significant bump and the air kicks on, then if I hit another bump, it'll kick back off. Obviously I've got a bad connection somewhere. Any ideas on what I can do to solve this problem without taking it to the dealer or mechanic? Fingers crossed that somebody else has had this issue!
    Thanks in advance - JC
  2. Jun 25, 2017 at 10:15 PM
    Vereor_Nox
    Vereor_Nox Fumblerooski
    North California
    2010 Tacoma TRD Sport
    First thing to do when diagnosing your AC is to get a set of manifold gauges. I used the "mountain r134" gauges from Amazon with good results. You might have to pull a vacuum on the system to make sure you dont have a leak. You can find the AC vacuum pumps on amazon and ebay. Check this guy for a good amount of info on how to get started.
    https://www.youtube.com/watch?v=rulXlnG2Unk
    Tex-Tac likes this.
  3. Jun 25, 2017 at 11:23 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Common issue is the blower fan connection or the connector to the fan itself. The blower is below the dash behind the glove box.
    https://www.tacomaworld.com/threads/fan-speed-switch-not-working.70275/
    You may need both connectors or only one check them both. Below is the parts and part numbers of what is needed to repair both.
    Part number 90980-10916 Connector
    Part Number 82998-12380 Wire and terminal
    Not sold as a kit, sold as each. So you will need one of the plugs and two of the terminal and wires.
    Connector:
    Terminals:
    You may also have a burned resistor connector and may need these:
    Plug Number 82141-04M40
    Resistor Number 87138-04052
    Taco man17 and Justinlhc like this.
  4. Jun 26, 2017 at 11:45 AM
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
    Sub'd
