A/C Issue
Discussion in '1st Gen. Tacomas (1995-2004)' started by AngryPanda86, May 28, 2019.
  1. May 31, 2019 at 6:57 PM
    Mark D.
    Mark D. Well-Known Member
    '96 base 4 cylinder Tacoma standard bed
    Added ARE fiberglass raised cap & Sony CD head-unit w' aux-input
    It's probably not the heater relay. Edited my previous reply for added info.
    Happy Motoring, Mark
  2. May 31, 2019 at 7:10 PM
    AngryPanda86
    AngryPanda86 [OP] Member
    Steven
    1995 tacoma 2.7L 4wd
    So Amplifier or Ac switch. ill start with the cheaper one and see what happens i suppose
  3. May 31, 2019 at 7:14 PM
    AngryPanda86
    Steven
    Oh and if its worth mentioning, the Ac button doesnt light up unless i disconnect the amplifier but that doesnt help \o/
  4. Jun 1, 2019 at 9:21 AM
    Glamisman
    Glamisman Well-Known Member
    here is how to check the amplifier.
    I dont have an answer for your harness missing a wire. I dont have an electronic copy of the AC wiring so I took a photo of it from the 96 factory wiring manual.
    • ovi.pdf
      File size:
      9.5 KB
      10
  5. Jun 1, 2019 at 2:09 PM
    tony2018
    tony2018 Well-Known Member
    CRAP, I forgot these toyotas have an amplifier thingie...Honda's I have don't have one.
  6. Jun 1, 2019 at 5:02 PM
    AngryPanda86
    Steven
    harness side
    4-ground pass
    6-2 pass
    2-10 857 ohms @ 92 ambiant (follows the Thermisitor chart)
    5-g ac switch on 8.37 Volts
    5-g ac switch off 0-
    I went to go test the back side, and i noticed theres a test for pin 8, There is no wire running to the harness on pin 8.
  7. Jun 1, 2019 at 5:08 PM
    AngryPanda86
    Steven
  8. Jun 1, 2019 at 5:18 PM
    AngryPanda86
    Steven
    it also appears the replacement instructions are slightly different? one says to replace amp if circuit doesnt match, and the other says replace it if it does? o_O
