A/C issue
Discussion in 'General Tacoma Talk' started by n4259r, Sep 7, 2024.
  1. Sep 7, 2024 at 6:56 PM
    n4259r
    n4259r [OP] New Member
    Garry
    2002 Double cab 4x4 Tacoma with six cylinder, base line.
    Winch and grill guard, Rhino liner over the entire vehicle.
    I don't know about HVAC so I need advice. There is a new "noise" when the A/C blower is on higher speeds and the passenger floor vent is spitting bits of insulation. I expect that there is some loose insulation in the vent ducting. I may be able to R and R the blower to clear the ducting but I don't even know how the insulation got there so I don't know how much I can remove without creating new problems. Ideas??? Thanks......GB
  2. Sep 7, 2024 at 7:21 PM
    Stuck in VT
    Stuck in VT Well-Known Member
    Utah
    2019 SR SX MGM
  3. Sep 7, 2024 at 7:33 PM
    n4259r
    Garry
    Hmm !!! I would have never thought of that. I don't think so as I have two, quite vigilant cats who visit my garage occasionally. I will definitely look into that possibility. Thanks for the idea.
    Knudsen likes this.
  4. Sep 9, 2024 at 2:25 PM
    n4259r
    Garry
    I got it all apart and cleaned out. While the blower was out, I could see that the intake air path, while convoluted, is not filtered or even screened. I expect that I picked up some "trash" insulation from the highway. The blower fan was packed tightly with insulation. I could get my hand up through the path to the engine side of the firewall.
    To rule-out mice (thanks for the suggestion) I surrounded the truck with mouse traps last night. None of them were disturbed. The task was actually quite easy. Thanks for the consideration. GB
  5. Sep 9, 2024 at 2:37 PM
    Stuck in VT
    Utah
    2019 SR SX MGM
    Glad you figured out! Need to start a thread in "off topic", random stuff mice drag back to their nests. Had a classic "Jerry hole" at work. That mouse dragged tissues, coffee stirrer, a screw and anything that couldn't be dragged in were left in a pile around the hole. Have heard of rat bait being moved and stockpiled in drawers. Little guys will be trapped and drag themselves to a safe spot. One member found a mouse double trapped dragging himself to the kill trap. Resilient little guys.
    Glad it wasn't mice!
    soundman98 and Steves104x4 like this.
