A/C Issues
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2002VH, Jun 6, 2019.
  1. Jun 6, 2019 at 7:44 AM
    2002VH
    2002VH [OP] New Member
    Vernon
    New Orleans
    02 Tacoma SR5
    I have a 2013 Tacoma with an A/C Issues. The A/C will operate great for 10 - 15 minutes then the compressor clutch disengages and the light blinks on the dash. If I press the A/C switch the A/C compressor will not turn back on, but if I wait approximately 10 minute and press the button the compressor will turn on again. The truck been back to the dealership twice now and the Compressor, Condenser, and Evaporator have been replaced. Does anyone have a suggestion as to what the problem may be?
  2. Jun 6, 2019 at 8:03 AM
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    You try replacing the pressure switch while you are in there firing the parts cannon at it? Expansion valve freezing up?
    Bishop2Queens6 likes this.
  3. Jun 6, 2019 at 11:21 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    What are the pressures when the system shuts off?
    SR-71A likes this.
  4. Jun 6, 2019 at 11:23 AM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    Faulty pressure switches can happen, although this is the first I've heard on a 2nd gen.
    The symptoms you described match my co-workers A/C issues last summer on his 2000 F250. It was the pressure switch.
  5. Jun 6, 2019 at 11:38 AM
    pinktaco808
    pinktaco808 Hot Steppa
    Overheat?
  6. Jun 6, 2019 at 3:17 PM
    08RC
    08RC Well-Known Member
    Just keep in mind if you change the pressure switch. Unlike any other truck I have changed one on their is no valve below the switch so when you unscrew it out goes your 134A .
    pinktaco808 likes this.
