A/C Light Blinking Troubleshooting Guide
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JCH, Jul 7, 2016.
  1. Aug 23, 2021 at 1:25 AM
    #101
    tomjo1
    tomjo1 Well-Known Member
    Tomjo
    Taiwan
    2007 Black Tacoma Sport
    2.5inch high life kit
    HI OP
    I got same issue (flashing A/C light) on my 07 Tacoma
    (When the A/C light flashing that the clutch is stopped rotating)
    May i know how to check the clutch is working normally ?
    I tried to rotating it by hand when the car off, it can be turned by hand, is this a normal situation?
    Thanks.
  2. Aug 23, 2021 at 1:29 AM
    #102
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    I posted my full experience in another thread but the issue with my AC light blinking was ultimately my belt tensioner.
    I have not had the issue since I changed it even though it didn't really bad enough to change it apparently it was allowing micro slapping of the belt and stuttering of the compressor pulley.
    The tensioner has either a spring or gas shock that provides the mechanical tension in the belt and a rubber isolator that dampens high frequency vibration, the dampener wears out before the mechanical pressure so you can have fine belt tension but still need to replace the tensioner itself, not just the pulley.
    PzTank, GilbertOz and BananaMan like this.
  3. Aug 23, 2021 at 4:51 PM
    #103
    tomjo1
    Tomjo
    Taiwan
    Do you have the part number for the belt tensioner ?
    Is this one ?
    Part Number: 1662031013
    Supersession(s): 16620-31013; 1662031011; 1662031012
  4. Aug 25, 2021 at 10:19 AM
    #104
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    A few weeks ago the AC light was blinking one one particular drive. Never happened again. Cold air has been weak but it’s also been hot af. Having the system recharged now, it was about 1/4 low.
    Worth changing out the relay and/or sensor as a preventive measure? No explanation for the single instance of the blinking.
  5. Aug 25, 2021 at 4:45 PM
    #105
    billnye1999
    billnye1999 Well-Known Member
    2013 Magnetic Gray Metallic Tacoma TRD Off-Road
    I would save yourself the cost and test the sensor if you can. The relay is cheap if you want to swap it just in case but you will never know if it worked until the issue comes up again and you still won't know for sure if its your relay or something else. My issue was similar to yours and the OP's but after testing the sensor I found it was fine. I hooked it all back-up and made sure the connections were tight and the ground was tight and clean and everything has been great since. The only thing I did change/replace was the relay prior (weeks before) to testing and it made no difference for me since the issue showed back up randomly after the change.
  6. Aug 25, 2021 at 5:03 PM
    #106
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    I had it in my head somehow that the relay and sensor were both inexpensive parts. Now that I see the sensor is $90 I’ll take your advice and review the instructions to test it. AC seems to be blowing fine since the recharge.
  7. Sep 26, 2021 at 12:32 PM
    #107
    bobank
    bobank Well-Known Member
    Bob
    Nutting Lake MA
    06 SR5 DCSB Silverstreak Mica
    New Frame, Leer Cap, Vent Shades, Timbren's, Interior LED's, Fluid Film, Royal Purple.
    My 2006 Tacoma has just started the blinking AC Light. I did hear a funny noise and smelled a burning rubber smell and the cool air went to hot. I have a great relationship with a garage in town and I will take it to them as soon as I can. I think we will be starting with the clutch and belts and all to see how we look and then go out from there. The Guide has given me a lot of info so at least when I talk to my mechanic I will have a good idea of where to start, but I am sure when he hears what happened he will know on his own where to start!
    Update when I get this figured out for sure.
  8. Mar 28, 2022 at 10:54 AM
    #108
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    I've got the intermittent flashing AC light and I have a couple of questions.
    The Magnetic Clutch Relay. Part# 90987-02028. Since I can see the clutch engaging for several seconds I'm guessing it's good. Can relays have intermittent problems? I see some people mention they pulled another relay to swap and test. My Denso relay is a light grey. The other Denso relays are a light blue and have a different number on them. Does that make any difference, like amp rating? As long as they fit is it OK to try them? I also notice the grey relay is resin sealed and the light blue ones aren't.
    The Compressor Pickup Sensor. Pulled it and tested fine. 2.7v which changed with a magnet. There is a little swelling of the plastic on top of the sensor and I thought that may be from something overheating inside but I can see a "dip" in the same spot on the OPs pic and now I think it's probably some deformation left from the manufacturing process.
    So relying on the idea the sensor and relay either work or don't work and won't have intermittent problems I'm moving to the other suggestions.
  9. May 22, 2022 at 4:09 AM
    #109
    Wajeone
    Wajeone Member
    2012 Tacoma Access Cab TRD Sport
  10. May 22, 2022 at 4:22 AM
    #110
    Wajeone
    Wajeone Member
    Thanks, good test!
    On my 2012 it was in the 90's and it was the first time I used it this season. I stopped for about 5 min and when I restarted the compressor clutch appeared to seize, belt squealed, burning belt smell. I shut it off and checked under the hood to see if the belt was on. I started the truck with the A/C off and checked everything without the A/C on first. Then while watching, I had my wife turn it on. The clutch came on so I had her turn it on and off and on again to confirm the clutch was still working.
    My original thought was the A/C go too hot and had too much pressure on one side causing it to lock up and when it cooled the clutch was working. Not the case, the A/C light was flashing and no cooling.
    There is still refrigerant in the system so that takes me to this post and I am going to test today.
    Thanks
  11. May 22, 2022 at 6:28 AM
    #111
    Stelcom66
    Stelcom66 Well-Known Member
    2007 2.7L 5MT 4WD
    My 2007 has similar symptoms, including the burning belt smell. For now, to be safe I removed the AC fuse. Don't want to activate it accidently. I'd be interested to see how you make out.
    Thankfully this unusually early heat wave is just this weekend with temperatures in the mid 90s. Glad to have the rear sliding window, will help a little bit for now.
  12. May 25, 2022 at 1:44 PM
    #112
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    My 2006 developed the blinking A/C light last fall. Decided to wait until spring to troubleshoot. Tried it a couple weeks ago, it was 90F+ out. It stayed on with no cool air. Long story short, it took out the clutch, compressor and belt. $1655 and change. Upside, I have A/C for Memorial Day weekend and my wife got a extended test drive of a Corolla that she has been eyeing:burnrubber: So we now have a Corolla on the way and I have A/C:D
  13. May 25, 2022 at 2:21 PM
    #113
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Lol. Sounds like you lucked out getting a good salesperson. Kudos to you.
    robssol[QUOTED] likes this.
  14. May 25, 2022 at 3:20 PM
    #114
    Stelcom66
    2007 2.7L 5MT 4WD
    I guess I have an idea what my AC situation is going to cost! Expected $1.000+ Glad you have AC, and another Toyota coming.
    I've had some Hondas, but now many models, even the CR-V come with a 1.5L turbo. I wonder how they'll be at 150,000+ miles.
    robssol likes this.
  15. Aug 8, 2022 at 11:44 AM
    #115
    Appleblues911
    Appleblues911 New Member
    2015 Toyota Tacoma off road
    Where is the best place to buy a compressor for a 2015. What brand other than Denso is good? Thanks.
  16. Oct 3, 2022 at 1:49 PM
    #116
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
  17. Oct 4, 2022 at 1:15 PM
    #117
    shmn
    shmn Well-Known Member
    Pacific NW
    2007 Tacoma 2.7L 5sp
    From Toyota. Generally speaking, OEM is always the way to go. New is about $210 (no clutch). I think they are Mahle now which replaced the Delphis (in my case).
  18. Oct 19, 2022 at 7:08 PM
    #118
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    @JCH thank you for being so thorough with your post! I changed my motor mounts and now my AC light is blinking after the compressor runs for a couple seconds. Scrolling through your reasons and I see the sensor... That I unplugged to get better access, and never plugged back in!
    :cheers:
  19. Mar 30, 2023 at 12:56 PM
    #119
    Mezvyk4200
    Mezvyk4200 Member
    So I started getting this blinking AC light recently. I thought it was the fuse and since it was a cheap option, I got one but didnt solve the problem.
    I then went under the car and found out that when they recently changed my alternator at the shop, they tore off the ground wire from the harness….
    lightly touched it back on, turned on and we good to go.
    Need to solder it in place now.
    Stelcom66 likes this.
  20. Aug 19, 2023 at 11:25 PM
    #120
    RyeTaco
    RyeTaco taco sauce only from Etsy FlatSixGraphics
    California
    2014 Tacoma TRD 4x4
    All stock except the K and N Engine air filter and the Cabin Filter K and N.
    To the JCH guy that made this post! You are brilliant! I have been trying to figure out this issue for a while and because of your post you helped me fix the issue. Thank you very much! Here is also another great tid bit. Instead of replacing the sensor I just cleaned it and reinstalled it and now it works! No more intermittent cutting off. No more flashing a/c button. This sensor is a hull sensor. It works just like a abs sensor. If the sensors get dirty they can cause intermittent readings and can cause a false signal. This sensor is mounted in the down position. So when you go 4 wheeling mud/dirt gets on the sensor. Even though its mounted to the a/c compressor body. Dirt can still get wedged between the sensor and the body of the a/c compressor. In order to diagnose something I first need to understand how the system works first. This post helped me understand how this system works. Thanks again Justin! Great job!
    JCH[OP] likes this.
