A/C Light Blinking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoma_SR5, Mar 25, 2012.
  1. Mar 25, 2012 at 5:02 PM
    Tacoma_SR5
    Tacoma_SR5 [OP] Well-Known Member
    Canada
    07 Tacoma SR5 Double Cab
    Hi there,
    This week I used my A/C in my 07 Tacoma truck and worked fine, and this weekend I noticed that when I turned on the truck, the A/C light was flashing and even if I pressed the button it would stay on then start flashing again after a few seconds. I read that it might be the relay so I used the Horn relay as a test and still get the flashing light.
    Also, when it flashed it's orange currently, when it's normal is it orange or green I forget?
    Anybody have any other suggestions of what I could check?
    Thanks guys.
  2. Mar 25, 2012 at 5:37 PM
    whopper
    whopper 2016 MGM 4x4 double cab
    wayne
    north carolina
    2016 tacoma double cab 4x4 MGM
    On going
    flashing light means your a/c system has a falt. have someone check it, clutch slip or some other problem
