A/C light still blinking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by k9srgn, Aug 9, 2019.
  1. Aug 9, 2019 at 12:22 PM
    k9srgn
    k9srgn [OP] Member
    Macey
    Mississippi
    07 4X2 regular cab
    2012 Tacoma. I replaced the A/C clutch sensor and the fuse and still no a/c and light still blinking. What is the next step? I REALLY don't want to go to the Toyota dealership. Any help will be greatly appreciated!
  2. Aug 9, 2019 at 3:40 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    Have power to the clutch?
  3. Aug 9, 2019 at 3:45 PM
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    Pull the plug at the compressor itself with the vehicle running. If you have around 14v its probs the sensor thats built into the compressor, which means its time for a new ac compressor. Ive also had ac’s work fine after clearing codes that were logged in the cars computer. So first check power, if you got power then clear all your codes. If its still blinking, replace the compressor.
    Edit: i see you replaced that sensor, have you evac recharged the system? Does the clutch even spin? Could be overcharged severly. Had a nissan yesterday with a whole water bottle full of dye in the system and after dumping it out of the low line and recharging it worked fine.
  4. Aug 9, 2019 at 4:49 PM
    k9srgn
    k9srgn [OP] Member
    Macey
    Mississippi
    07 4X2 regular cab
    I noticed the compressor isn't kicking on so next I'm going to ck the refrigerant. btw, I'm a woman and not a mechanic. I'm simply trying the things I can do before big bills with the Toyota Dealership.
  5. Aug 9, 2019 at 6:03 PM
    S.B.
    Sean
    San Diego
    15 Taco
    Also check the clutch relay/ swap it with another relay ie horn
  6. Aug 9, 2019 at 6:15 PM
    k9srgn
    k9srgn [OP] Member
    Macey
    Mississippi
    07 4X2 regular cab
    Okie dokie! More things to ck after refrigerant check I'm going to try the refrigerant in the morning and go from there I'll let you know the results (fingers crossed). You are a great group to offer help and I'm thankful
    Additional note: The guys at the parts place were laughing, because they have had Toyota people in all summer with the same problem
    MurderedTacoV2 likes this.
  7. Aug 10, 2019 at 9:55 AM
    Taco'09
    Taco'09 Well-Known Member
    OP, when was the last time your system was recharged? If it is on the original charge from '07 my efforts would take me first to a low charge. You can do this quick check and see if it may possibly be a low charge issue. Open hood. Located on the metal line coming out of the condenser toward the firewall is an electrical switch near the radiator but high up toward the passenger side. The switch is a high/low pressure switch and serves to kill operation of the compressor if either too much pressure or too little.
    Disconnect the electrical connector itself from the switch (Do not attempt to unscrew the hex nut part of the switch; leave the switch alone and attached!!). The connector will have just two wires: probably a white with black stripe wire, and a beige wire. With the electrical connector off bridge the two terminals within the connector with a short wire or paper clip and start the engine and activate the AC. Does the magnetic clutch now engage? If so, that tentatively points to low charge or bad pressure switch.
  8. Aug 12, 2019 at 5:46 PM
    k9srgn
    k9srgn [OP] Member
    Macey
    Mississippi
    07 4X2 regular cab
    Nothing worked. Had a mechanic look and he did all the things y'all suggested+ How much does run to get the Compressor replaced at a Toyota dealership?
  9. Aug 12, 2019 at 5:52 PM
    S.B.
    Sean
    San Diego
    15 Taco
    does the compressor turn by hand?
  10. Aug 12, 2019 at 6:27 PM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    Did the mechanic say the compressor is shot? If he is not sure, take the truck elsewhere, but not to the dealership $$$
    Jimmyh and b_r_o like this.
  11. Aug 13, 2019 at 7:16 AM
    k9srgn
    k9srgn [OP] Member
    Macey
    Mississippi
    07 4X2 regular cab
    I just went ahead and dropped it off at the Toyota dealership this morning. It wouldn't take the refrigerant. We tried everything everyone suggested. Stay tuned and I'll let everyone know what it turns out to be
  12. Aug 13, 2019 at 10:23 AM
    Muddinfun
    Muddinfun Well-Known Member
  13. Aug 13, 2019 at 10:47 AM
    k9srgn
    k9srgn [OP] Member
    Macey
    Mississippi
    07 4X2 regular cab
    :spending:lol!
    Muddinfun likes this.
  14. Aug 13, 2019 at 11:20 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Wasn't it more like $1,600 last time?:rofl:
    Muddinfun[QUOTED] likes this.
  15. Aug 13, 2019 at 2:47 PM
    Wbarbi
    Wbarbi New Member
    I have a 2010 tacoma flashing ac light. Fuses all good relay is good. Clutch not engaging. Applied power at relay and clutch engaged light still flashing and air still warm. Relay not receiving ground from amplifier to energize. My pressure switch has continuity, suspect amplifier.
    Appreciate any thoughts, thank you.
  16. Aug 13, 2019 at 2:49 PM
    k9srgn
    k9srgn [OP] Member
    Macey
    Mississippi
    07 4X2 regular cab
    Okay guys, ready....$2,800:boom:
  17. Aug 13, 2019 at 2:51 PM
    S.B.
    Sean
    San Diego
    15 Taco
    Sounds like compressor, clutch, flush system and evaporator?
  18. Aug 13, 2019 at 2:58 PM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    Find a small mom and pop shop.. Don't say or show anything that the dealer said, is bad. Have them tell you what's wrong and give you a quote
  19. Aug 13, 2019 at 3:43 PM
    k9srgn
    k9srgn [OP] Member
    Macey
    Mississippi
    07 4X2 regular cab
    Yep, all 3. Already had someone else look at it and said it was probably that. Toyota would need to repair it.
  20. Aug 13, 2019 at 3:45 PM
    k9srgn
    k9srgn [OP] Member
    Macey
    Mississippi
    07 4X2 regular cab
    Heat index here was 121°. I'm a veterinarian and I need my truck asap
