A/C manure smell
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CusterFan, Jun 1, 2017.
  1. Jun 1, 2017 at 1:29 PM
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    have you pulled the air cabin filter just for shits and giggles??
    CusterFan[OP] likes this.
  2. Jun 1, 2017 at 1:30 PM
    RyanL
    RyanL Well-Known Member
    Indiana
    15 TRD Pro, supercharged, BP-51s, etc
    I hear the A/C doesn't stank on Ridgelines
    GPsevinSixx likes this.
  3. Jun 1, 2017 at 1:37 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    frigi fresh ac deodorizer. thanks me later
  4. Jun 1, 2017 at 1:41 PM
    coopcooper
    alberta canada
    CusterFan[QUOTED][OP] likes this.
  5. Jun 1, 2017 at 1:46 PM
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    I open all the windows for a minute then close them again. In the summer 9/10 times it's cooler outside then inside my truck.
    *This is to replace all the hot air in the truck. Truck cools down quicker this way for me
  6. Jun 1, 2017 at 2:15 PM
    DRJ1014
    DRJ1014 Well-Known Member
    CA
    Yep. Use the whole can. Make sure they have it in stock. My local places they have to order it in.
  7. Jun 1, 2017 at 2:21 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Still trying to figure out how a cow can piss on a high Tacoma hood and windshield :confused:
  8. Jun 1, 2017 at 2:30 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    :worthless:
  9. Jun 1, 2017 at 2:39 PM
    nDub
    Lead Free Gasoline
    Possibly following a truck pulling a trailer full of cows?
  10. Jun 1, 2017 at 2:40 PM
    oldschoolczar
    oldschoolczar Well-Known Member
    '16 DCSB TRD OR
    You don't need any of this air freshener shit if you just make it a practice to switch it to fresh air mode occasionally. Haven't had odor issues since I started doing that.
  11. Jun 1, 2017 at 2:42 PM
    SilverBullet19
    SilverBullet19 Well-Known Member
    Scott
    Sacramento County
    2015 DCLB Prerunner TRD Sport
    maybe not manure...but I had a stale musky smell from my AC. I went to Pep Boys and bought the AC deodorizer bomb, it was like $6. I can't remember the brand, but NOT the type you spray into the vents, that stuff is pointless. You spray it into the vent and the system pushes it right out.
    This one you set right at the AC air intake dealy, under the passenger footwell. Put the AC on full blast, press the button on the can, and close your car door. Let it sit that way for 10-15 minutes while this stuff goes off (the can will spray for a couple minutes straight, the rest is to let it work through the system). Then open the doors and let it air out for about 15 minutes.
    So it takes like a half hour, but I just sat there with a beer while I let the stuff work its magic in the driveway. Eliminated odor, and left a very nice "fresh" scent for a few weeks. It actually lasted longer than most air fresheners. I use it every six months or so now. It works great, and its cheap. I need to get a can for the wife's car, I'll let you know what the brand is.
  12. Jun 1, 2017 at 2:56 PM
    TheCookieMonster
    TheCookieMonster cookies!!!!!!!!!!!
    North East
    1995 Hi Lux 22re 4x4 5speed
    Michelin MS2 K&N drop in filter
    spray Lysol in the HVAC intake vent on the cowl under the wiper blades
  13. Jun 1, 2017 at 3:10 PM
    MaidenTheTrooper
    MaidenTheTrooper Well-Known Member
    2017 Tacoma SR5 2.7
    So far wheels & tires
    This tastes like the cow got into an onion patch.
    stun gun, RyanL and over60 like this.
  14. Jun 1, 2017 at 6:23 PM
    DRJ1014
    CA
    Never tried through the cabin air. It's easy for our trucks though, just slide under the truck, don't even need to lift it up and stick it in the drain tube
  15. Jun 1, 2017 at 6:36 PM
    #35
    tacoflavoredkisses1
    tacoflavoredkisses1 Well-Known Member
    16 TRDOR DCSB (SOLD)
    I believe that's the actual tip from Toyota to fix it. Someone posted a link a while back.
  16. Jun 1, 2017 at 6:41 PM
    #36
    over60
    Muskoka, Ontario
    Or, maybe the cow ate her way thru the asparagus patch..??
  17. Jun 1, 2017 at 6:48 PM
    #37
    FlintHillBilly
    FlintHillBilly BIG FAT DAVE
    Not Dave
    Flat Lands
    14' Reg Cab 4x4
    Toyota
    I've actually noticed this a few times in my 2nd gen (2014) after I got it. Usually after the weather warms up and I first turn the AC on. I literally checked the bottom of my shoes when I got the whiff. New cabin filter or not.
    It wasn't as strong as strong as manure but distinctive - similar I guess. Between weird and new smell.
    I don't smell it anymore and I've done none of the above.
  18. Jun 1, 2017 at 8:06 PM
    #38
    LS14ME2
    LS14ME2 Kind of a big deal
    In hiding, CA
    2017 SSM Sport DCSB 4x4
    Center console divider thingy, rubber bed mat and side steps for the wife.
    Our Avalon does the same thing and had the same complaints when it came out. Defaults to recirc. mode and rarely changes.. What I do is manually change to outside air when I use the A/C.. My vette and the Camry I had would start in recirc and change to outside air after a bit.
  19. Jun 1, 2017 at 8:16 PM
    #39
    Pittrider
    Pittrider Pitty, those needing correction.
    Greg
    B.C.
    2016 MGM LTD LB
    Do you need to know, or care?
    Are you sure it's the a/c? i don't have this issue so might want to be checking your passenger (not thinking you of course :bananadead:)
  20. Jun 1, 2017 at 8:29 PM
    #40
    Tom Servo
    Tom Servo Dickweed
    Thornton, CO
    2013 DCSB TRD Sport
    As someone who grew up around this, let me just say that you might be overreacting. cowpie.jpg
