A/C manure smell
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CusterFan, Jun 1, 2017.
  1. Jun 3, 2017 at 10:15 AM
    #61
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    I'm going to have to try this. My wife and I picked up a 2007 Civic for her to use as a gas sipper commuter and intermittently it smells like vomit coming from the vents. Cabin filter has been changed so I'll give this stuff a try.
    CusterFan[OP] likes this.
  2. Jun 3, 2017 at 3:25 PM
    #62
    jgw
    jgw Yapping for over six decades
    Joe
    Western Montana
    2017 Tacoma Double Cab 4X4 TRD Off Road Quicksand
    Ultra flex tonneau, bed mat, Ionic nerf bars, weathertech mud flaps and floor mats
  3. Jun 3, 2017 at 7:12 PM
    #63
    nevadabugle
    nevadabugle Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    This. I can run the recirculator all I want. As long as I turn it off before shutting down the truck there is no smell. If I forget....smells like a girl I used to date.
    RyanL[QUOTED] likes this.
  4. Jun 3, 2017 at 7:24 PM
    #64
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    It's usually my 26 yr old son who let's one go outside then jumps in the truck and shuts the door quickly and has this grin on his face then the whole cabin fogs up...
  5. Jun 6, 2017 at 8:14 AM
    #65
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    Any update on this OP?
  6. Jun 6, 2017 at 8:33 AM
    #66
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    I regret ever doing the lysol through my cowl. Never again. Not only did it not work, but months later it still smelled.
  7. Jun 6, 2017 at 8:46 AM
    #67
    GPsevinSixx
    GPsevinSixx Well-Known Member
    Ros Angerus
    2015twoAX2.4techPAWS
    6112/5160AALfnCNTSTRyokG015
    This is what the dealer uses.
    http://carspecmn.com/toyota-and-lexus-air-conditioning-odor-prevention-and-repair-of-foul-air/
    For some who have never seen the inside of the HVAC unit, the Evaporator core lives in there and this is the shit that can grow inside. You can pull the cabin filter and spray the purifier/ disinfectant/ AC refresh as the fan runs. You can see the fan impeller once the filter is out. Some have used bleach diluted with water, but I don't recommend doing that as the bleach may discolor your interior fabric parts as it expels through the vents. We used to spray through the cowl intake before vehicles had cabin filters, but the method through the fan works better as it gets you closer to the EVAP core.
  8. Jun 9, 2017 at 2:32 PM
    #68
    TRD493
    TRD493 Well-Known Member
    Dave
    Texas (DFW)
    17 TRD Sport DCLB 4x4 / 01 4x4 V6 Extra Cab TRD SR5
    To avoid the "crappy" smell I always turn my A/C off a couple of miles before my destination, usually work and home, and run my fan on high to dry up the condensation that will build up in the vents caused by shutting it off. Generally the condensation is dried up before shutting the car off and I have been able to avoid the smell. I've done this in several cars I've owned, one is a 95 Civic, and never had a problem with smelly vents.
  9. Jun 9, 2017 at 2:39 PM
    #69
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    Correction?
  10. Jun 9, 2017 at 2:41 PM
    #70
    TRD493
    Dave
    Texas (DFW)
    Have you tried what the user in post #87 recommended? It sounds less invasive than letting the dealer take the dash apart.
  11. Jun 9, 2017 at 2:58 PM
    #71
    Deet
    Deet Well-Known Member
    Tracy, CA
    2016 White TRD Off-Road 4x4 DCSB
    I had the same thing going on in my 2001 Sequoia. This only ever happened when I started my Sequoia after having parked it on a hot day, without shutting the A/C off. Apparently this has to do with A/C condensation forming in the vent system somewhere and developing a kind of harmless bacteria that smells like dirty gym socks and blue cheese if left to fester in the sun. When you'd get back in and start up, the smell would be there, but would vanish within a few seconds after the vents were hit with the cold air again.
    I found the only way to relieve this condition long term, was to turn the A/C off a minute or two before reaching my destination, so as to allow the warm air to dry the condensate in the vents up a bit before shutting the motor off. The next time I started it up, the smell would not be there.
    CusterFan[QUOTED][OP] likes this.
  12. Jun 9, 2017 at 4:05 PM
    #72
    Deet
    Tracy, CA
    Well, I doubt your solution would work for most folks, but it looks like you may have at least solved your own issue! I say run with it! :rasta:
  13. Jun 9, 2017 at 4:06 PM
    #73
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    It's Eau de TurdGen :D
    over60 and nDub like this.
  14. Jun 9, 2017 at 4:15 PM
    #74
    TheCookieMonster
    TheCookieMonster cookies!!!!!!!!!!!
    North East
    1995 Hi Lux 22re 4x4 5speed
    Michelin MS2 K&N drop in filter
  15. Jun 9, 2017 at 4:52 PM
    #75
    dpgreen
    dpgreen Well-Known Member
    Doug
    Raleigh, NC
    2016 4x4 Access Cab
    This happened with my wifes 2016 BMW as well as my Tacoma. From what I have read there are two issues with leaving the truck on recirculate, both having to do with excess water causing growth of bacteria. . The first is inside air is always higher humidity than outside air, even when it is raining believe it or not. Humans generate a lot of humidity. That means that the air hitting the evaporator will generate more condensation and have more possibility for condensation throughout the system. The second is that the closed system on recirculate doesn't leave as good of a path for the liquid to evaporate once the system is turned off (a path to the outside drier air).
    The recommendations for fixing the root cause of the problem were to run outside air when possible, limit using recirc to the initial cooling of the car, always make sure you have it on outside air when you stopped, and if you want to go as far as possible with it turn the AC off a few minutes before stopping to dry out the system completely (which I don't do).
    In terms of getting rid of the existing smell (kill the bacteria), the recommendations were to run the heater to dry out the system, then run a can of Ozium (available on Amazon) through the outside intake. It seems to have worked for me for both the Tacoma and BMW.
  16. Jun 9, 2017 at 5:40 PM
    #76
    Deet
    Tracy, CA
    Ouch. Different deal, then. If it's that bad, I'd fall back and punt using the possible solution in post #87. PITA, I know, but if it's that bad, it might be worth it.
    I'm with everybody else who wonders why Toyota's climate control system always has to default to the "cabin re-circulation" setting. :frusty:
  17. Jun 29, 2017 at 6:03 PM
    #77
    Squidward
    Squidward Well-Known Member
    17 OR DCSB Tech/Prem/JBL awesomeness
    KO2 Bros, SCS Ray10s, Tint, LEDs
    My 16 had this issue, my 17 and even my rental/loaner 17 did. I think its a mold issue with the routing for the AC drain. Need to crawl up under there and do some more diagnosing.
  18. Jul 25, 2017 at 8:28 AM
    #78
    CusterFan
    CusterFan [OP] Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    #78
  19. Jul 25, 2017 at 8:43 AM
    #79
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
