A/C not blowing cold...compressor or system recharge?
Discussion in 'Technical Chat' started by Graham.R, Jun 27, 2011.
  1. Jun 27, 2011 at 8:28 PM
    Graham.R
    Graham.R [OP] New Member
    Graham
    Victoria
    06 TRD Sport 4x4
    I have had my 06 tacoma for about 4 months now and the A/C dosnt seem to blow very cold. Im just curious if the compressor will kick in if the system needs to be re charged? I dont hear the compressor kick in now, just woundering if it's worth getting it re charged or is it mabye the compressor itself, fuse, plugged lines etc..
  2. Jun 27, 2011 at 8:33 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    if its very low on freon ,the compressor will not come on.
  3. Jun 28, 2011 at 5:54 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    The only way to tell what's going on is to put a set of gauges on it. It will tell you what each side of the system is doing.
    Underfilling or overfilling causes the same problems=loss/poor cooling. Buy/borrow gauges, google the correct readings/causes, and go from there.
    Let me know what you find.
    Freon is r-12. Suva is R-134a
