A/C Not Draining?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Norsemanvike, Oct 20, 2018.
  1. Oct 20, 2018 at 8:59 PM
    Norsemanvike
    Norsemanvike [OP] Well-Known Member
    Escondido, CA
    '18 Sport 4x4, DblCb, ShBd, BBP
    @OR4x4
    Friends truck...
    Folks, wired situation. New ‘18 OR, we did the A/C drain mod, but there was no condensation dripping out. There was air blowing out, but no condensation. Concerned, we pulled the drain mod off and the OEM drain had no condensation either. The A/C unit was blowing on full blast on max cold for nearly 20 minutes and not a drop. Truck was really cold inside. Discussing the issue, a realization was made... in the 30 days of ownership, very little condensation has been noticed under the truck even before the A/C mod.
    Thoughts?
    Planning on taking it to a reliable dealer on Monday since it seems odd.
    OR4x4 likes this.
  2. Oct 20, 2018 at 9:07 PM
    Tacoma2020
    Tacoma2020 Well-Known Member
    Dry air.
    vprgts, JCT86, StayinStock and 2 others like this.
  3. Oct 20, 2018 at 9:07 PM
    Bishop84
    Bishop84 Well-Known Member
    I wouldn't address a modification unless something is truly wrong.
    A/C doesn't pool unless its crazy hot and humid here.
  4. Oct 21, 2018 at 2:45 AM
    OR4x4
    OR4x4 Well-Known Member
    Portland, OR
    2018 DCLB 4x4 TRD-OR Super White
    Could be dry air? But Norsemanvike's truck started dripping within seconds of turning on. And the trucks were side by side. Same humidity and heat outside.
    The 18 OR was on for 20 minutes, full blast, max AC, not a single drop. The 18 Sport (Norsemanvike's) fires up his truck and literally immediately had water coming out.
    Thoughts on that?
  5. Oct 21, 2018 at 3:28 AM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    My '16 was like that and about 1 and a half years later it started smelling like cow manure when the a/c was on. Praying I don't have that issue with my new '19 SR. But if I do it will go to the service dept. :)
  6. Oct 21, 2018 at 4:40 AM
    OR4x4
    Portland, OR
    Can you give more details? One and half later? As in 1 and a half hours later? I've driven my truck for 2+ hours in the high desert, no smell.
    Or 1 and a half years later?
  7. Oct 21, 2018 at 10:21 AM
    CusterFan
    I'm sorry. Yes a year and a half later. I live in Illinois and the summers are hot -n- humid. Here are some threads to look through.
    https://www.tacomaworld.com/search/6987736/?q=evap+core&t=post&o=date
    Norsemanvike[OP] likes this.
  8. Oct 21, 2018 at 10:27 AM
    CusterFan
    Norsemanvike[OP] and hiPSI like this.
  9. Oct 23, 2018 at 10:53 AM
    Norsemanvike
    Escondido, CA
    CusterFan likes this.
  10. Oct 23, 2018 at 7:02 PM
    OR4x4
    Portland, OR
    AC is draining fine now... Just have been an unusually dry day in SoCal. Glad I'm not having any problems with my AC.
