A/C not turning on even after installing new parts
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Smurf rig329, Jul 2, 2020.
  1. Jul 4, 2020 at 8:43 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I don’t doubt you have checked the fuse.
    How are you checking the fuse?
    If it an LED test light, try a different method.
    Those things don’t always tell the truth.
    Just ask @12TRDTacoma
    Muddinfun and 12TRDTacoma like this.
  2. Jul 4, 2020 at 9:05 PM
    Muddinfun
    Muddinfun Well-Known Member
    Jimmyh and TnShooter[QUOTED] like this.
  3. Jul 4, 2020 at 9:06 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    It's true, LED test lights are a diagnostic aid, but they should be treated exactly like that, an aid. They should not be treated as be all end all in testing condemnation of parts in question, because they have been known to give false positives in the past. In order to ensure continuity is flowing through whatever fuse is in question to eliminate it beyond any shadow of doubt, a dedicated DVOM with an integrated ohmeter mode should be used.
    Most of the time you can get away with testing it with something like a power probe, but when the issue involves digging and tearing deep into fuse boxes, internals and maybe even your HVAC system, you want to make sure that base is covered and 1000% known good.
    TnShooter[QUOTED] likes this.
  4. Jul 4, 2020 at 10:25 PM
    TnShooter
    Deogee
    STOCK
    I’m by no means “good” with electrical, but I’ve been learning. Slowly, very slowly.
    I came across a video, where they were diagnosing a window issue.
    There was power, and ground, every where it should be, the window motor was good.
    The problem was in the switch, It had continuity, what it didn’t have was the ability to carry the current.
    I see why electrical work is expensive.
    Sometimes, it takes a lot for work to figure it out.
    Jimmyh, Muddinfun and 12TRDTacoma like this.
  5. Jul 4, 2020 at 10:40 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Electrical can be a difficult one to work on sometimes. Even myself who has been working and messing with it for years, I still get taken to school about it.
    People complain all the time about pricing for electrical, but they gotta remember, you aren't paying me for what I can do, you're paying me for what I know.
  6. Jul 5, 2020 at 5:18 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    No power on relay pin 1 nothing will happen no ground on relay pin 2 nothing will happen. If you are using a voltmeter check voltage between pin 1 and pin 2 key on any speed. It takes a pretty good short to take out a 50 amp fuse your probably talking smoke first.
    12TRDTacoma and Jimmyh like this.
  7. Jul 5, 2020 at 7:59 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I've been doing electrical / electronics for 47 years and I learn something daily....
  8. Jul 5, 2020 at 8:40 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I got 16 years of automotive under my belt, but truthfully probably like 11 or 12 of electrical.
    Jimmyh[QUOTED] likes this.
  9. Jul 6, 2020 at 4:27 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Everything goes along fine until you let the smoke out.
    Jimmyh likes this.
  10. Jul 6, 2020 at 12:59 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Plumbers make more. And they can keep it. I deal with enough shit as an electrician. I don't want to deal with it literally.
    Jimmyh and 12TRDTacoma[QUOTED] like this.
  11. Nov 13, 2020 at 12:20 PM
    Scdude
    Scdude Member
    Scott
    2010 Toyota Tacoma 4x4
    Sorry for not getting back to this topic sooner, was in the process of moving and buying and selling a home.
    The 50 amp fuse in position 2 in the above picture will blow as soon as the motor starts to rotate, it will not blow until connected to the fan motor. I did get the fuse block to separate and found no shorts or issues of any kind in there. If you all can continue to help me troubleshoot this I would appreciate it.
    Thanks
  12. Nov 13, 2020 at 12:47 PM
    TnShooter
    Deogee
    STOCK
    Does the 10A A/C fuse blow also?
    Does either one blow with the resistor hooked up?
  13. Nov 13, 2020 at 4:21 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    If the 10 Amp A/C fuse also blew then the problem is in the A/C Amplifier circuit.
    If the 10 Amp A/C fuse did not blow then you have a problem with the Blower Motor, Resistor, Blower motor switch or the associated wiring.
    CurtB and TnShooter like this.
  14. Nov 16, 2020 at 3:38 AM
    Scdude
    Scdude Member
    Scott
    The 10a Fuse doesn't blow, I did get a new blower motor so it isn't that. I checked out all the wiring from the blower motor back to the firewall and see no problems. Next move will probably be the resistor, where is the blower motor switch located?
  15. Nov 16, 2020 at 4:58 AM
    #35
    Jimmyh
    SC
    2012 Prerunner SR5
    The blower motor switch is in the control panel in the dash, left hand knob for motor speed.
    How are you checking the wires? You probably need a Digital Multimeter to do a good check. Look for grounds and short circuits.
    From your above post it indicates that the 50 amp fuse doesn't blow when the motor is disconnected.
    Is this true?
    That would indicate that the blower motor is the issue.
    Then you say you replaced the motor and it still blows the 50 ampere fuse.
    TnShooter likes this.
  16. Nov 16, 2020 at 6:48 AM
    #36
    Scdude
    Scdude Member
    Scott
    Correct, with the blower motor not connected nothing blows, turn off everything and connect the blower motor, turn the key and the blower moves just a little bit and then the 50 amp blows.
  17. Nov 16, 2020 at 9:06 PM
    #37
    Jimmyh
    SC
    2012 Prerunner SR5
    I assume when you disconnected the blower you are disconnecting the two wire plug on the motor correct?
    Now try this. Unplug the resistor 4 wire connector and leave it disconnected.
    Turn on the truck and try and run the fan on high setting. Note: The lower settings don't work with the resistor disconnected.
    Did it blow a fuse this time?
    If the fuse blew again the issue is the Blower Motor.
    If the fuse did not blow the issue is the resistor assembly.
    TnShooter and CurtB like this.
  18. Nov 17, 2020 at 4:03 AM
    #38
    Scdude
    Scdude Member
    Scott
    I will give that a try this week and report back, thanks.
    Jimmyh likes this.
  19. Nov 17, 2020 at 4:22 PM
    #39
    Jimmyh
    SC
    2012 Prerunner SR5
    :thumbsup:
  20. Nov 30, 2020 at 4:55 AM
    #40
    Scdude
    Scdude Member
    Scott
    The plug for the blower motor apparently got warm and the connectors were loose so I ordered a new plug, once it comes in I will be testing to see if the resistor is faulty.
    Thanks again.
    Jimmyh likes this.
