A/C not working after having steering box replaced at dealer
Discussion in '3rd Gen. Tacomas (2016-2023)' started by brennaman, Jul 31, 2025 at 7:16 PM.
  1. Jul 31, 2025 at 7:16 PM
    brennaman
    brennaman [OP] Member
    phil
    2021 TRD offroad
    Took my son's '21 tacoma off road in to the dealership to have a leaking steering box replaced under warranty repair. Took it home and the A/C does not work. With the temp set to 60 degrees, it just blows warm air. Press the A/C button and it illuminates for a few seconds then flashes and goes off. I tried to listen to the compressor turn on, the idle goes up a few RPM, but I don't hear the compressor kick on. I looked for the fuse under the hood, and it is empty, so the model with the auto temp must not have a fuse there. There are no wires for the fuse to plug into. Any ideas what they may have left off, a connector somewhere that I can't seem to locate? He is going to try to call the dealer in the morning, but I doubt they will be able to get him in. August in Missouri can be miserable without A/C. Any ideas? Phil
  2. Jul 31, 2025 at 7:35 PM
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    Call the dealer and don’t take no for an answer. They screwed it up, guaranteed.
  3. Jul 31, 2025 at 7:42 PM
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
    -edit: I was wrong, he found the connector to the compressor disconnected.
    My money is that they damaged the line, gas leaked and your a/c is no longer working. I’ve done racks in the past and that Freon line is ridiculously close to other lines and the rack. Remember, Freon does not vanish it goes somewhere and that somewhere is a hole. cheers!
    Greg-tacoma, Chew and Phlogiston like this.
  4. Jul 31, 2025 at 7:43 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The flashing A/C light means the compressor rpm and engine rpm do not match.
    The compressor has a plug on it, see if it is plugged in.
    You have an RPM discrepancy....
    DES2009 and Phlogiston like this.
  5. Jul 31, 2025 at 8:30 PM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    A@!#$@$%#$%
    The wild west
    2016 SR5 DCSB
    take it back to the dealer
    Greg-tacoma, Chew and t0p_d0g like this.
  6. Aug 1, 2025 at 5:39 AM
    brennaman
    phil
    2021 TRD offroad
    I called the dealership and they are going to try to get us in next week. (my son has to go out of town for the weekend) I am sure they screwed it up, I am going to try to find the hi and low pressure switchs to make sure they are plugged in, I tried to find a connector on the compressor, but could not see one. It is not that hot this weekend, so he will be fine for the weekend.
  7. Aug 1, 2025 at 5:47 AM
    Clearwater Bill
    Billy
    Largo Florida
    Usually on top, close to the front. If disconnected there should be dangling wire
  8. Aug 1, 2025 at 7:14 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Next week?
    Go down there and don't leave until they look at it
    rtzx9r and t0p_d0g like this.
  9. Aug 1, 2025 at 7:21 AM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    Guy locally to me did that.
    They trespassed him, and he spent the next three weeks on the sidewalk right-of-way with a cardboard sign stating his grievances.
    I always wondered, what if anything at all, that did to the dealer's sales..
    rtzx9r, t0p_d0g and b_r_o[QUOTED] like this.
  10. Aug 1, 2025 at 7:31 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    If they nicked a line, they KNEW they let the cold out. You don't ''overlook'' that. Why they would unplug it I don't know, you're not working anywhere around it and unplugging it doesn't affect the pressure anyways. Off, it equalizes anyways on the high/low sides.
  11. Aug 1, 2025 at 8:34 AM
    brennaman
    phil
    2021 TRD offroad
    Well I got a chance to look at it in the daylight. Not that the light helped, the connector on the back of the compressor was not connected. Plugged it in and we have A/C. Thanks all, now a call to the stealership. Phil
    rtzx9r, Jakerou, Ricardo13x and 2 others like this.
  12. Aug 1, 2025 at 12:13 PM
    Ricardo13x
    Upland, CA.
    lol niceeeee well done sir! Sometimes is that simple.
  13. Aug 1, 2025 at 10:31 PM
    rtzx9r
    Bueller
    2016 TRD Sport
    Don’t settle. Go back to the dealer and firmly make them make it right. Give you some $$ back at minimum. You shouldn’t need to fix your truck after they monkeyed with it.
    Phlogiston likes this.
