A/C Off but still blowing air?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hawkeye12, Sep 30, 2010.
  1. Sep 30, 2010 at 11:57 PM
    hawkeye12
    hawkeye12 [OP] Go Pack Go!
    Bryce
    Raleigh, NC
    10 Black DC SB Tacoma TRD Sport
    Smittybilt nerf bars
    So the other day I was making a 5 hour drive and I put down my windows and turned off my AC. I was driving for a little while and noticed that there was still air blowing out of the vents. I rolled up the windows and the air continued. The knob on the far left was set to "Off" and I cannot figure out what is going on. I know one of you guys got the answer for me!
  2. Sep 30, 2010 at 11:59 PM
    slick_711
    slick_711 Well-Known Member
    DFW, TX
    '09 TRD Off Road
    Avid light bar w/2x Hella 4000C, Bilstein 5100s, Demello sliders
    Every truck I've ever owned did that to some extent. I never questioned it, as I like to have a little bit of circulation even when I don't want to alter the temperature of the air. In short, I don't know why, but why not?
  3. Oct 1, 2010 at 12:00 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Air from outside still comes in. If you want it totally off, turn the fan nob off and press the recirc button.
  4. Oct 1, 2010 at 12:02 AM
    hawkeye12
    Bryce
    Raleigh, NC
    Thats the thing, I have the fan nob off. And its not just like a little air flow, its about the air speed you would get from having your fan nob set to the 2nd setting.
  5. Oct 1, 2010 at 12:07 AM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Did you press the Air recirc button on?
    Cause otherwise it will still come in pretty good while driving.
  6. Oct 1, 2010 at 12:08 AM
    Bz3r0
    Bz3r0 Smackalicious!
    Bryan
    Edwards AFB, CA
    White 2017 TRD Offroad
    Under Construction
    That's what Krazie is saying... Even if you do have your fan nob all the way off, vented air from the outside will still come in. This is the case with every vehicle I've owned, and its meant for air circulation. If you don't want vented air coming in from the outside, with everything turned off climate control knob-wise, there's an air-recirculation button under your vent selector knob that once pushed, will close the vented air ducts in your dash, and no longer allow air to come into your cab. Make sure the LED light is Illuminated...
  7. Oct 1, 2010 at 12:10 AM
    hawkeye12
    Bryce
    Raleigh, NC
    Yes, this is with the recirc button on.
  8. Oct 1, 2010 at 12:10 AM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    ^I was far too lazy to type all that but yes, that's what I was getting at.
    Edit - I blame witchcraft then.
  9. Oct 1, 2010 at 12:17 AM
    Bz3r0
    Bryan
    Edwards AFB, CA
    Under Construction
    Try verbally insulting your 'Coma, and then if that doesn't work, I'd take it back to the dealership to get it looked at. Motors within the dash control the vents and they should close when that button is illuminated. Did you try pushing the button and seeing (when the button is not illuminated) if the air flows? Its possible they could have rigged it backwards...
    Edit: Disregard... Try what whippersnapper02 suggested. I've never heard of that before.
