A/C on tacoma not holding R134A
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Carl_z33, Jun 17, 2019.
  1. Jun 18, 2019 at 12:31 PM
    #41
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    Here's the thing. It's great that you do your own work and save money. I think most of us work on our own stuff here. But there are reasons why you need to pull a proper vacuum before you add refrigerant. When AC oil mixes with moisture, it becomes acidic. That can cause an early death for your compressor and cost way more to fix than just the line. The moisture can also freeze in the lines, cause oil sludge, and plug critical orifices. The fact that your system has lost pressure more than once indicates that it may have moisture in it already (before you replaced the hose). So, what we really are doing here is trying to save you money. I am just drawing the ugly picture to make it clearer.
    CurtB, Bebop and Carl_z33[QUOTED][OP] like this.
  2. Jun 18, 2019 at 12:50 PM
    #42
    Carl_z33
    Carl_z33 [OP] Well-Known Member
    Carl
    2014 Toyota Tacoma TRD OR 4x4 DCSB
    The entire line was leaking, not just the o-ring
  3. Jun 18, 2019 at 12:51 PM
    #43
    Carl_z33
    Carl
    Yes! I saw that video before. His videos are great
  4. Jun 18, 2019 at 12:54 PM
    #44
    Carl_z33
    Carl
    Thank god there are no penguins in SoCal
    72.99
  5. Jun 18, 2019 at 1:11 PM
    #45
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    You purged refrigerant in California? You’re lucky your not in prison! :rofl:
    Jimmyh and CurtB like this.
  6. Jun 18, 2019 at 1:17 PM
    #46
    Carl_z33
    Carl
    That was the joke .... :boink:
  7. Jun 18, 2019 at 1:54 PM
    #47
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    But did you pull a good vacuum? It's important to do.
    Bebop likes this.
  8. Jun 18, 2019 at 2:43 PM
    #48
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Yes it is... In so many ways.
    Bebop likes this.
  9. Jun 18, 2019 at 3:46 PM
    #49
    Inferno!
    Inferno! Well-Known Member
    El Dorado Hills
    2018 TRD OR Inferno 285/65/17
    Supercharger, sway bars, lift, leather, tires, Gobi, etc.
    *drink*
    Bebop[QUOTED] likes this.
  10. Jun 18, 2019 at 6:02 PM
    #50
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    I never even banged her when we were actually dating; Luckily I cut it off before it got that far!
  11. Jun 18, 2019 at 6:05 PM
    #51
    PennSilverTaco
    Charlie
    @Bebop
    We kissed and made out plenty of times, and I did some things that I will not mention publicly, but I stopped communicating with her after probably less than a month of dating her.
    Bebop likes this.
  12. Jun 18, 2019 at 6:33 PM
    #52
    Bebop
    Nick
    Good idea. Best to stay out of baby jail!
  13. Jun 18, 2019 at 6:38 PM
    #53
    PennSilverTaco
    Charlie
    Seriously...
    I am holding onto my Tacoma because I don't want payments. Child support is even worse than car payments!
    mackw10 and Bebop[QUOTED] like this.
  14. Jun 20, 2019 at 7:26 PM
    #54
    Carl_z33
    Carl
    Hooked it up to my friends machine to do it properly
    CurtB[QUOTED] and oni06 like this.
  15. Jun 20, 2019 at 7:51 PM
    #55
    Bebop
    Nick
    Start to finish in 30 min with a proper vacuum, doubt it
  16. Jun 20, 2019 at 7:53 PM
    #56
    Carl_z33
    Carl
    30 min for the hose my guy. The machine he has did the rest.
    Why does refilling a truck with this crap seem so unrealistic to you??
  17. Jun 20, 2019 at 8:23 PM
    #57
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    I think you meant to say it took 30 minutes to R&R the line. Then pulled a vacuum and recharged. Right?
  18. Jun 20, 2019 at 8:25 PM
    #58
    Carl_z33
    Carl
    Took 30min to replace the line & then we hooked it up to his machine. He has a some machine that he uses at his shop to release the air & refill the refrigerant. We literally hooked up 2 hoses, H & then L & the machine did the work. At the end we unhooked the H & refilled the truck up with the refrigerant lol
  19. Jun 20, 2019 at 8:29 PM
    #59
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    :thumbsup:I think you did it right!
    Carl_z33[QUOTED][OP] likes this.
  20. Jun 20, 2019 at 8:40 PM
    #60
    oni06
    oni06 Well-Known Member
    I think @Bebop is concerned about the proper capturing and recycling of the R134a refrigerant.
    If you just released it into the atmosphere thats a big no no as far as the EPA is concerned. Though R134a isn't ozone destroying its still a greenhouse gas. Then again we also release greenhouse gases every time we exhale so *shrugs*.
    Refilling takes longer because you need to pull a vacuum on the system to evacuate all the atmosphere and moisture that was let into the system. This process alone is normally 30 min or so. Then you should leave the vacuum on the system for like 24 hours to make sure the leak is fixed prior to recharging the system.
    I am not going to assume one way or the other unless you came on here and straight up admitted you released the refrigerant into the atmosphere.
    Bebop likes this.
