A/C on tacoma not holding R134A
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Carl_z33, Jun 17, 2019.
  1. Jun 20, 2019 at 8:45 PM
    #61
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Every time I crack a system open I vacuum it for at least an hour to make sure all the moisture is out. Even longer if it’s a humid or rainy day. I was giving him shit about purging refrigerant with him being in commiefornia.
    oni06[QUOTED] likes this.
  2. Jun 20, 2019 at 8:46 PM
    #62
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    This is not the proper way to leak test.
  3. Jun 20, 2019 at 8:48 PM
    #63
    oni06
    oni06 Well-Known Member
    I am not a professional so please explain.
    Otherwise your post is useless.
  4. Jun 20, 2019 at 8:50 PM
    #64
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    I'm going to bed, google it. If need be I'll explain tomorrow, good night.
  5. Jun 20, 2019 at 9:09 PM
    #65
    oni06
    I have.
    I am sure there is more than one way of doing it depending on if the system is charged or not.
    In an empty system it makes sense to me if you pull a vacuum and then wait a awhile you should still have a vacuum on the gauges. If there is a leak you wouldn't have a vacuum anymore.
    I have read about other methods for when the system is charged such as soap and water, uv-dye, etc..
    Any additional info is appreciated.
  6. Jun 20, 2019 at 9:10 PM
    #66
    oni06
    I am also in commiefornia :(
    Bebop[QUOTED] likes this.
  7. Jun 21, 2019 at 1:20 AM
    #67
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The misleading part was when you posted this statement which reads as though it was start to finish in 30 minutes.
  8. Jun 21, 2019 at 4:23 AM
    #68
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    If there is a leak, under vacuum it will be pulling in air and water vapor. Then the system has to be pressured up to find the leak, fix it, then vacuum again. It just takes longer.
    I prefer using dry nitrogen to pressure up and leak test.
    There are many ways to skin a cat. :)
  9. Jun 21, 2019 at 5:28 AM
    #69
    Taco'09
    Taco'09 Well-Known Member
    How about a deep vacuum to really dry that thing out.
