A/C on with defrost
Discussion in '3rd Gen. Tacomas (2016-2023)' started by slthomps, Apr 25, 2018.
  1. Apr 25, 2018 at 6:34 AM
    slthomps
    slthomps [OP] New Member
    5th Tacoma this one is a 2017. I have modified all the previous ones so the A\C compressor does not come on when in Defrost mode and I could press the A\C button if needed. In other words, I do not want the A\C compressor to come on automatically when in Defrost mode.
    How do I make this change?
    tonered likes this.
  2. Apr 25, 2018 at 6:54 AM
    Freetime
    Freetime Well-Known Member
    2016 TRD OR AC 4x4 Quicksand
    Ok. What are you asking? Or are you just making a statement?
    MGMTaco17 and pltommyo like this.
  3. Apr 25, 2018 at 6:57 AM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    ...that's the whole point though? Fogged windows are the result of too much humidity. The A/C compressor dehumidifies. Without it, all you're doing is heating the windows such that water in the air won't condense to them. With the A/C compressor you're removing humidity as well, solving the root cause of the problem.
  4. Apr 25, 2018 at 7:03 AM
    slthomps
    95% of the time the A\C compressor does not need to be on for Defrost to work. Having the A\C compressor on when it is not needed affects the mpg. This is a simple modification to get better mpg.
    AeroCooper and tonered like this.
  5. Apr 25, 2018 at 7:10 AM
    CTF
    CTF Well-Known Member
    2017 TRD OR
    That annoys me too. Not so much that it could affect MPG but that you can’t override it.
    tonered likes this.
  6. Apr 25, 2018 at 7:17 AM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Not if you are using defrost to help with snow and ice. Even with the temp setting on hot, the AC compressor will still be on in defrost mode on a lot of cars.
    AeroCooper likes this.
  7. Apr 25, 2018 at 7:22 AM
    Chris Miles
    Chris Miles Well-Known Member
    2016 Toyota Tacoma
    Trailer Hitch Cover - Star Wars Pulp Fiction Boba Fett & Stormtrooper
    I own a 2017 Tacoma. The air conditioner automatically comes on when I turn on the defroster. I do not like this.
    I've owned 4 other Tacomas and was able to alter or override the A/C during defroster setting.
    Is it possible to alter this in my 2017 model?
    Thank you.
    AlabamaBlackSnake likes this.
  8. Apr 25, 2018 at 7:25 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    +1 I'd like to have full control. Our previous cars let us do that. During the winter, I need a bit more airflow but not a/c to keep my windshield happy.
    It is also a bit crazy that if you go full left on the temp control by accident, both A/C and recirc will turn on. Then, I'm poking at buttons to turn it all off.
  9. Apr 25, 2018 at 7:26 AM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    It's what it is designed to do. Most all vehicles do it. It is necessary! I seriously doubt you can see significant MPG changes by ocassionally using the defroster.
    What js312 said.
    G.
  10. Apr 25, 2018 at 8:00 AM
    js312
    Joe
    New England
    It's still beneficial, that's why it's designed that way. Humans exhale very humid air, so you'll cause the humidity in a small space like a truck cab to rise rapidly. In turn, that'll cause condensation on the windows. The A/C compressor helps to prevent that.
    Rock Lobster and Hemibee like this.
  11. Apr 25, 2018 at 8:15 AM
    slthomps
    OK. Everyone look at my first post. I asked how to fix this. I am not interested in anyone's opinion. If you don't know how to fix this, please don't post anything.
  12. Apr 25, 2018 at 8:59 AM
    Freetime
    edit - I see the edit you made now.
  13. Apr 25, 2018 at 9:28 AM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    That was rude.
    I'm almost positive I turned mine off with carista or somewhere in the vehicle settings from the head unit.
    Otherwise dealer would be able to with tech stream. Dunno where I did it for mine but remember it was one of the first things I did when I got it.
    Monday_Rex likes this.
  14. Apr 25, 2018 at 10:31 AM
    jowybyo
    Joe
    Baltimore, MD
    I understand that. I just don't want the A/C on everytime I want the defrost on. When I need to get the fog off my windshield then yes, A/C on is good. When I just need to keep my wipers from freezing to the windshield, then no I don't want it on. I realize it doesn't hurt anything, I'm just controlling like that :thumbsup:
    BearWithMe, Joe23 and tonered like this.
  15. Apr 25, 2018 at 10:51 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I don't know about the 2017's. But I haven't owned a vehicle in YEARS that automatically turned the AC on when the defrost was on. I have 3 vehicles in the driveway now, an 07 Tacoma, an 09 Honda, and a 14 F-150. All of them require me to manually turn on the AC if I want to dehumidify. I can run the defrost without the AC, but almost never do. Personally I wish the AC would come on automatically like it did years ago.
    Either way this is a huge non-issue.
    You might see .1 or .2 difference in MPG's. You're way over thinking this.
    stealthmode likes this.
  16. Apr 25, 2018 at 10:55 AM
    montanacruiser
    montanacruiser Well-Known Member
    2017 DCLB Off Road
    I turned mine of in settings in head unit.
  17. Apr 25, 2018 at 11:13 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Sorry, but I just wanted to check. If you enable / disable this setting, the a/c will not come on if you move the vent knob to the last three defrost settings?
    If so, High5! I will dig in an find this.
    shakerhood likes this.
  18. Apr 25, 2018 at 11:28 AM
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    Just curious (and yes, I'm ignoring your request by posting this) how much gas does the ac really use? 1/2 a mpg? 1/4 mpg? Just seems like a lot of work for a negligible amount improvement.
  19. Apr 25, 2018 at 11:33 AM
    stealthmode
    stealthmode Well-Known Member
    Alberta
    2016 Short N Stubby Bed- MGM
    Front and Rear lifts Tires ECGS bushing Lots of other crap +HP sticker
    In some enviroments I could see the AC having little effect for defrost being on or off.
    No mods other than putting it on foot vent and defrost? Crack a window and your defrosted. Boom.
    Also trying holding AC for a few seconds toggling it on/off?
  20. Apr 25, 2018 at 11:40 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Cracking a window does work well, but in the winter when you just want heat. . .
    That is one of the problems this automatic A/C issue. It doesn't light the A/C button. Holding it down would be difficult to tell if it turned off.
