A/C only blows cold while driving
Discussion in '1st Gen. Tacomas (1995-2004)' started by cadman33619, Aug 25, 2012.
  1. Aug 28, 2012 at 8:29 AM
    pippen
    pippen that was'nt a vitamin!!
    Pippen
    Eastern NC
    04 PreRunner Ext.
    My 2004 Prerunner blows ice-cold at idle and at highway speed, there is something wrong with yours. I'm no expert on this but from what I've read it could be a "idle up circuit", bad fan clutch. I've heard alot of vehicles from factory have a dye in their freon for checking leaks, but it sounds like you have plenty of freon OP.
  2. Aug 28, 2012 at 10:51 AM
    BamaToy1997
    Bill
    Navarre, FL
    1st gen also uses a belt driven fan. My 1st gen blows ice cold at idle, AND at speed. The AC system should always blow cold, regardless at idle or not, so there is definitely a problem somewhere.
  3. Aug 28, 2012 at 11:00 AM
    MRBOND101
    MRBOND101 TTE
    Dylan
    Frisco, Texas
    16 TRD-OR AC
    Yea same here. Definitely not normal though for your truck to be doing that.
  4. Aug 28, 2012 at 11:03 AM
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    easy... u have a restriction or ur fan clutch is bad. look between ur radiator and the condensor. alot of times theres a bunch of shit all on the radiator restricting flow. so only while the trucks driving does the condensor have air flow through it. or the fan clutch is bad and not "sucking" air.
  5. Aug 28, 2012 at 11:18 AM
    BamaToy1997
    Bill
    Navarre, FL
    Already been mentioned earlier....:D
  6. Aug 28, 2012 at 11:23 AM
    lotsoftoys
    Jace
    Denver
    bunch of crap
    too lazy to read. but i gaurentee thats it
  7. Aug 29, 2012 at 5:29 AM
    BamaToy1997
    Bill
    Navarre, FL
    Another car psychic !! :rolleyes:
  8. Aug 29, 2012 at 8:41 AM
    cadman33619
    cadman33619 [OP] Well-Known Member
    my first gen (2004) does not have a dedicated AC fan. i'll check for blockage today as lotsoftoys suggested. is the clutch something that only a shop can change?
  9. Aug 29, 2012 at 8:46 AM
    blakes09
    blakes09 Toyota Tech..when im not Fishing
    Blake
    Deep South
    4x4
    ^^^^ this
  10. Aug 29, 2012 at 10:31 AM
    BamaToy1997
    Bill
    Navarre, FL
    The fan clutch is a job that can easily be tackled with basic hand tools.
  11. Aug 31, 2012 at 6:53 PM
    cadman33619
    I'm pretty confused...so forgive me for sounding like an idiot here.... Is the fan clutch attached to the AC compressor? Or is it attached to the radiator fan? From what I see in the repair manual, it looks lie its attached to the water pump but I don't see it. Can someone explain exactly where the fan clutch is for the AC?
  12. Aug 31, 2012 at 7:01 PM
    blakes09
    Blake
    Deep South
    4x4
    ok if you crank the truck,turn on the AC and hold the RPM to about 2500(truck parked ,not moving)will it blow cold?
  13. Aug 31, 2012 at 7:10 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    solenoid tripping on and off ?
    You should be able to hear the ac solenoid click on (engage)
    and click when it goes off (disengage).
    Does the solenoid click on when you drive
    and click off when parked at idle ?
    take a listen to that and tell us what you hear
  14. Aug 31, 2012 at 9:51 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Fan clutch is the large piece that attaches the cooling fan to the drive pulley.
    The AC clutch is on the front of the AC compressor.
    When the AC engages, the clutch energizes and begins to spin.
    The fan always appears to spin, but when the clutch engages it's more solid and doesn't slip.
  15. Aug 31, 2012 at 10:19 PM
    #35
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    The fan should be engaged on startup, then freewheel until its engage temp is reached.
    Without a dedicated ac fan, the ac will not blow as cold as when you are moving, or when the fan is engaged. If there is another problem with your ac, it will make the problem more obvious.
    Make sure your condenser fins are straight and free of foreign material. Leakdown test, and tire pressure are irrelevant troll references.
  16. Aug 31, 2012 at 10:27 PM
    #36
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Cooling fan.
  17. Sep 1, 2012 at 6:47 AM
    #37
    crazybill
    crazybill Member
    Bill
    Caliente, CA
    Stock 2002 Xtracab TRD
    Camper shell, K&N, high flow ex, Hella 500 lights, Portable Warn 9000 winch, CO2, Thule rack.
    Quite a few possible causes for your problem, most already mentioned here. Unless you are willing to buy a set of AC gauges and are willing to learn how to use them it is impossible to determine the exact cause.
    Take it to a good AC shop and let them sort it out.
    -Bill-
  18. Sep 1, 2012 at 10:40 AM
    #38
    cadman33619
    Tacodell, when parked and I turn the AC on I can hear the solenoid clicking on. But when I turn the AC off I do not hear a click. Gonna take it on the road with the AC on and listen for the click and let you know..
    blakes09, With the truck on and AC on in park, if I hold the rims at 2500 the AC blows nice and cold.
  19. Sep 1, 2012 at 11:20 AM
    #39
    cadman33619
    Ok...drove for 10 miles and didn't hear the solenoid click not once. I listened with the window open and closed.
  20. Sep 1, 2012 at 11:24 AM
    #40
    Rich91710
    Rich
    Los Angeles
    08 Base
    I don't think you can hear it when moving with the hood closed.
    Just take it to a shop. You don't have the tools or skills to properly troubleshoot this.
