A/C only blows cold while driving
Discussion in '1st Gen. Tacomas (1995-2004)' started by cadman33619, Aug 25, 2012.
  1. Sep 1, 2012 at 2:05 PM
    #41
    cadman33619
    cadman33619 [OP] Well-Known Member
    The guy at the auto store suggested replacing the low pressure switch. Where is that located?
  2. Sep 1, 2012 at 2:11 PM
    #42
    Round II
    Round II Member #12005
    This. Mine was not super cold at a stop either this however changed when I did an electric fan conversion.
  3. Sep 1, 2012 at 3:01 PM
    #43
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    You're going to trust a guy that makes $8 an hour and doesn't actually get paid to work on cars?
    The low pressure switch MIGHT be out of calibration, but most likely not.
    They usually either work or they don't.
    Without knowing what your pressures are and EXACTLY what the compressor clutch is doing, you have no way of knowing what the LP switch should be doing.
    If your clutch is engaged and the compressor is running at idle, the LP switch it just fine.
    It is SUPPOSED to disable the compressor under certain operating conditions... one of which protects the compressor from being damaged by an insufficient charge.
  4. Sep 1, 2012 at 3:45 PM
    #44
    Fenwick1993
    Fenwick1993 Hillbilly
    Not Fenwick
    Chesapeake, VA
    96 Tacoma 5Lug, 2015 PreRunner
    Stonewall is the fattest 5 lug slug ever
    Hey there. My neighbor's 2000 Volkswagen Golf has the same problem- if the car is not in motion, (not going above 2k RPM) his AC blows un-cold air. With his, he said that there is a fan that will not engage until then- I believe he called it a clutch fan. Maybe that's the same problem you're having.
  5. Sep 1, 2012 at 6:40 PM
    #45
    cadman33619
    I cant really say I trust the guy at the auto store. I just hate to take it to an overpriced AC shop who I know will not be honest with me about what they really found. It could be something really simple but they will not tell me....I'm sure they will find another excuse to overcharge me. However...it looks like I have no choice.
  6. Sep 1, 2012 at 11:25 PM
    #46
    BamaToy1997
    Bill
    Navarre, FL
    There has GOT to be more than one place in town that can look at it and tell you what is wrong. Hell you will spend more time guessing and throwing parts at it than getting it diagnosed properly.
  7. Sep 2, 2012 at 12:18 AM
    #47
    Rich91710
    Rich
    Los Angeles
    08 Base
    +1
    Shotgunning parts is what auto parts store guys are good at... and it's good for sales.
    It's not their money.
    Internet advice often runs the same way. Everyone has their own experiences. "X" was the problem when I had an issue so I'm going to be likely to suggest that. Tom encountered "Y" so he's going to suggest that.
    Both might be issues... WE don't know without more information, and getting that information requires input from someone with a good understanding of the systems.
    It's like an O2 sensor code, Autozone will sell you a new O2 sensor.
    Just maybe, that sensor was doing it's job and a problem in the engine was causing the code? That's why techs make a lot more than Autozone employees.
  8. Sep 6, 2015 at 1:16 PM
    #48
    ChemDawg
    ChemDawg Well-Known Member
    Maine
    2005 sr5 4x4
    I have this same problem on my 05 tacoma.
    When I got new frame (from recall) I had dealership put in a new ac. Works great while moving then warm parked.
    I do drip water when ac is on so am I reading these pages right by thinking my problem may be the fan.?
  9. Sep 6, 2015 at 1:19 PM
    #49
    Cbass38
    Cbass38 Well-Known Member
    sebastian
    scottsdale
    07 pre runner
    projector hids,wheels,small lift,flowmaster
    1000% positive you need more airflow across the condenser..get an electric fan and your good to go.
  10. Sep 6, 2015 at 7:23 PM
    #50
    ChemDawg
    Maine
    2005 sr5 4x4
    By electric fan u mean.........o_O
  11. Sep 6, 2015 at 10:15 PM
    #51
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '03 cbr954rr, '03 rc51
    I installed two 8" e fans recently. And only noticed a VERY minimal increase in efficiency. By minimal I mean it only keeps it slightly colder for longer idling. however it may be due to the fact that they are so small as well. And I don't think the cfm is all that great. $80 down the drain. I'm planning on taking it in to a family owned shop to have it checked out. Too much work and too many variables for a newb like me to mess with and risk screwing up even more. It should work better without any modifications like it did from the factory.
  12. Sep 7, 2015 at 10:29 AM
    #52
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Mine has the same problem, I just crank up the fans to max and recirc and wait for Fall.
  13. Sep 7, 2015 at 2:14 PM
    #53
    ChemDawg
    Maine
    2005 sr5 4x4
  14. Sep 8, 2015 at 2:01 PM
    #54
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    Mine does the same. It blew warm the whole time. I took it to a shop and it is cold when the truck is moving but anytime I'm stopped it isn't warm but it isn't freezing like when I'm moving.
  15. Sep 13, 2015 at 7:20 AM
    #55
    Fenwick1993
    Not Fenwick
    Chesapeake, VA
    Its airflow
  16. Sep 24, 2015 at 2:09 PM
    #56
    TravelinLight
    TravelinLight Well-Known Member
    Hayes
    Pensacola, FL
    Bilsteins on front and rear, OME 885 coils, Wheeler's AAL with overload left in, LR UCA's, Stock TRD 17" wheels, 255/75-17 BFG KM tires, VIPMOTOZ headlights, Lifetime LED headlight bulbs, 6000K LED Fog bulbs, Jumper's Interior and license plate LED's, Husky Classic floor mats, OEM bed mat, Leer100R truck shell with carpeted platform, de-badged, white derped grill emblem.
    Hey BamaToy it's Hayes here in Pensacola. I'm having this issue on my 08 and I'm not the best at checking these types of things. Still need some electrical work done. Can we look at this soon?
  17. Sep 24, 2015 at 3:14 PM
    #57
    BamaToy1997
    Bill
    Navarre, FL
    I am sure we can figure out something. Will be next week before I have the free time though.
  18. Sep 24, 2015 at 3:21 PM
    #58
    rzgkane
    rzgkane Well-Known Member
    Huntington Beach, CA
    2019 Tacoma TDR Sport 4WD DCLB - Cement - Tech and Premium
    4Runner Trail wheels and Toyo Open Country ATII tires 265-70-17. Cosmetic stuff like Pro grille and OffRoad black bumper trim, vinyl delete on side, added hood graphic, OEM tube steps.
    You probably had HVAC ducts that were controlled by engine vacuum. These trucks do not work that way.
  19. Oct 11, 2018 at 10:54 AM
    #59
    freshtacomaowner
    freshtacomaowner Active Member
    Eric
    2007 Tacoma
    a few just starting out
    I know old thread but good info anytime, common issue for any A/C system, could be lots of things, most commonly it is low airflow across condenser (in front of radiator) I have witnessed dirty fins that can't even be seen , flush with a good cleaner, I use acid type cleaner that foams and pushes dirt and debris out (works good on radiators as well, seen 20 degree drop on bug filled radiators) hard on paint, so wet paint first before use and don't let it dry! The gallon jug I have says dilute, I use latex gloves str8 and pump sprayer, make sure no or little wind and remove glasses after use a shower maybe necessary, if that doesn't help check fan clutch and charge of 134 (should be ok tho, since gets cold when moving)these are a good starting point, 134a condensors are extremely sensitive to heat transfer on condenser coils, as a side note with this condition extended you'll have higher than typical high side pressures and that stresses compressor and acc drive belt and idlers as well.
  20. Oct 11, 2018 at 11:04 AM
    #60
    freshtacomaowner
    Eric
    2007 Tacoma
    #45 if electric fans it gets more tricky, computer controlled? or trinary or binary switch in the mix? Is the signal for A/C on good? power through switch? Fuse good? good connection as well? Relay working properly?trinary or binary switch coming on at proper pressure? does A/C have separate controller?wire pinched? or a short in wire? either control or fan power? one simply issue is not always so simple as more and more computer controls are introduced
