A/C only blows while driving
Discussion in '2nd Gen. Tacomas (2005-2015)' started by trd_arlen, May 24, 2018.
  1. May 25, 2018 at 8:13 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I think he's talking about the flow of refrigerant through the system
  2. May 25, 2018 at 8:49 AM
    JimIowa
    JimIowa Well-Known Member
    Jim
    Des Moines, Iowa
    2015 TRD OR DCSB
    "Park Avenue" ACDF horns
    I had the same problem with a Maxima, but heat not a/c. Hot heat only at high revs. Cold air at stop lights. Had a plugged or restricted coolant line or heater core. Disregard if my comment here doesn't move with your a/c problem.
  3. May 25, 2018 at 5:21 PM
    SeafireXV
    SeafireXV Well-Known Member
    Olathe, KS
    2006 Tacoma TRD Sport ACLB
    Its your cabin air filter. Pull your glovebox and change your filter. I know it sounds simple, but I’ve been there and done that.
  4. Jun 7, 2025 at 2:08 PM
    GeneralTimber
    GeneralTimber New Member
    Tim
    2005 Tacoma 4dr 4wd
    3in lift billsteen , ko2 tires, ARE Topper, upgraded sound system touch screen, prinsu roof rack,
    Make sure to check your cabin air filter! I noticed that my A/C worked well while driving, but it would become warm when idling at traffic lights.
    After reading about similar issues, I decided to inspect my cabin air filter. While doing so, I discovered that some paperwork from the glove box had fallen over the return air intake, blocking airflow from the cabin. Once I removed the paperwork, my problem was resolved.
