A/C outlet....has anyone found a use for it yet?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by lbhsbz, Jul 15, 2024.
  1. Jul 15, 2024 at 11:19 AM
    lbhsbz
    lbhsbz [OP] Well-Known Member
    400W ain't much, and 100W is pretty much nothing. I've owned several trucks with the A/C outlet in the bed and haven't found a single thing that it's actually useful for. What do you use it for?
  2. Jul 15, 2024 at 11:20 AM
    saajanpatel1
    saajanpatel1 Well-Known Member
    Saaj
    MA
    2022 Tacoma Limited
    None
    I charge my tool batteries, i know a bit light use but it helps.
    I also used it to charge my laptop for a project where i had no trailer.
    four22, Koolbreeze7 and auskip07 like this.
  3. Jul 15, 2024 at 11:21 AM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
  4. Jul 15, 2024 at 11:21 AM
    mtip
    mtip Go Outside & Play!!!
    South Louisiana
    18 TRD Sport 6MT 00 Tundra 5MT
    X-mas, & a month or so later, Mardi Gras lights
    But that's about it for me
  5. Jul 15, 2024 at 11:22 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    I plugged an incandescent lamp into it one evening to see if it worked (it did), and I haven't touched it since.
  6. Jul 15, 2024 at 1:16 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    Christmas lights and charging tool batteries
  7. Jul 15, 2024 at 1:22 PM
    PNW AV8R
    PNW AV8R Active Member
    Eugene, OR
    23' TRD SPORT
    pretty stock
    Had a blackout for three days and used it grind coffee beans and charge cell phones, that's all
  8. Jul 15, 2024 at 1:24 PM
    Nirango kid
    Nirango kid Well-Known Member
    Gilles
    Ontario
    2021 Tacoma TRD Sport Premium in Barcelona Red
    I think you can only use it with the truck running or with ignition on but not sure. Is there someone here with experience with it.
    kahanabob likes this.
  9. Jul 15, 2024 at 1:32 PM
    Horseshoez
    Horseshoez Well-Known Member
    Dale
    Maryland
    Out camping, I run an extension cord from it to my CPAP machine.
    Old goat1914 and Beerpayzdabillz like this.
  10. Jul 15, 2024 at 2:17 PM
    lbhsbz
    So you let the truck idle all night?
  11. Jul 15, 2024 at 2:18 PM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    this was my question. that sounds insane, lmao
    bjohn041 likes this.
  12. Jul 15, 2024 at 2:22 PM
    lit_taco4x4
    lit_taco4x4 IG and YT: @2a_crawlcamper
    Louie
    2018 Tacoma TRD Pro
    JD fab LT, Archive and Deavers, King shocks, Dual locked, Dual T case, Tundra steering rack, 39’s
    it works without the truck running? I must have the wrong CPAP machine.
  13. Jul 15, 2024 at 2:29 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    I use my Goal Zero 12v port - works like a champ for days. This thing powers the camper inside lights and outdoor string lights as well.
    Cell phone recharge / camera battery recharge - I love these things.
    Battery gets low on juice?.... just open up the solar panels and recharge (as I'm doing below).... and if nearby just use shore-power.
  14. Jul 15, 2024 at 2:32 PM
    lit_taco4x4
    Louie
    2018 Tacoma TRD Pro
    I used an Ecoflow for my CPAP before I got the mouthpiece device that Joe Rogan talks about. My question was more about the AC outlet working without the ignition on. Yeah I know you can make the AC outlet work without truck running but you’d have to do some electric fuckery to make that happen. My question was more if you could run it straight from the AC outlet straight up without the fuckery part and running truck on.
  15. Jul 15, 2024 at 2:52 PM
    2021SR5V64WD
    Right, understood, and I'm sure you could but I have no idea how to make that work.
    Seems like it would eat a lot of juice plugged in like that.
    I run my Dometic off another 12v port in the truck but it is wired for ignition on.
  16. Jul 15, 2024 at 6:13 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Air mattress, Cell phone, Drill/impact battery, Ironically a jump pack lol, job fan, lights.
    Nothing life changing, but it's nice to have when you need it. I typically use a battery generator nowadays though for bigger stuff.
    Edit: I did use for an air pump in a bait bucket once, so I guess it was life changing for some creek chubs lol.
  17. Jul 15, 2024 at 11:05 PM
    BTL Y-Wing
    BTL Y-Wing Well-Known Member
    2020 Army Green TRD Pro
    Bed outlet, not so much, especially since I got a portable power station with close to the same output. My main use was getting a kit to add an AC plug in the cabin on the same inverter circuit as the bed outlet, so now when I turn it on it also powers an outlet on the back of the center console which actually is useful for recharging devices on the go.
  18. Jul 16, 2024 at 2:31 AM
    Tucker2020!
    Tucker2020! Well-Known Member
    I use it to charge my Jackery (while driving). The Jackery powers my fridge. This helps me avoid having to use a 12-24 volt transformer to fast charge my Jackery. Fridge barely uses 50W. AC outlet charges the Jackery close to 100W. Always ready to go once I hit the camp site where I would just plug the solar panels to the Jackery.
    G2.M6, JPTx, BRFab and 4 others like this.
  19. Jul 16, 2024 at 4:12 AM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    I actually used mine to run a sump pump.
    3hp I believe, neither the truck or pump was happy but it did it with truck running.
    Lost power during a storm VT had with all the flooding.
    grogie likes this.
  20. Jul 16, 2024 at 4:37 AM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    50 foot extension cord and flood light to deal with flat tires in the dark. Junky Pittsburgh polesaw worked fine for about the 15 minutes I needed it before I had a gas pole saw.
