A.C. Outlet in cab mod question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Subdewd, Feb 17, 2015.
  1. Feb 17, 2015 at 4:09 PM
    Subdewd
    Subdewd [OP] Well-Known Member
    Pearl Harbor, HI
    15 TRD OR 4x4
    I just finished the always 400W mod and added an outlet in the cab to support charging some basic electronics etc. I purchased a Leviton dual USB outlet. Everything seemed to go smoothly but when I tested the USB connection to charge my phone, nothing happened. I can plug in something else to run in the receptacle and it powers up just fine. The USB just doesn't work. There's nothing in the instructions that makes me think I missed something, simply hot, neutral, and ground. Anyone ever seen this/had this problem before? Thanks!
    Here's the outlet I'm using.
    http://t.homedepot.com/p/Leviton-Decora-15-Amp-Combination-Duplex-Receptacle-and-USB-Charger-White-R02-T5632-0BW/205092277
  2. Feb 17, 2015 at 4:50 PM
    Jefes Taco
    Jefes Taco Well-Known Member
    Denver, CO
    14' DCLB TRD Sport supercharged
    No issues for me. Mine works great.
    You didn't test it before you put everything back together?
    Easy enough to pull it apart and check. I'd get a new outlet now and have it on hand when you pull it all apart. In case it's just a bad outlet.
  3. Feb 17, 2015 at 5:10 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    probably the output of the inverter itself.... its not a typical sine wave AC current... the USB charger probably does not like this and goes no thanks.
    That stated they make all sorts of good 12v usb car chargers, and you wont even have to use your AC for that. Seems kind of pointless to go 12v -> 120v -> 5v usb
  4. Feb 17, 2015 at 5:36 PM
    Bender581
    Bender581 Well-Known Member
    AL
    Arkansas
    2012 4X4 Tacoma
    Gobi roof rack. Icon coilovers, Icon tubular UCAs, FOX 2.0 rear shocks, Icon 3-leaf progressive AAL.
    I don't know about this one outlet, but some types have different power (amps) at each port. Example: 1.1 apps on the left and 2.2 amps on the right.
  5. Feb 17, 2015 at 6:43 PM
    DanceswithWolves
    DanceswithWolves palabra a tu madre
    Jerry
    Roosevelt UT
    13 DCSB OR
  6. Feb 18, 2015 at 2:55 AM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    Wife has the same scoshe outlet. Been working a couple years now. I have an old scosche outlet that sticks out a couple inches. Worked for several years now.
  7. Feb 28, 2015 at 7:34 PM
    Subdewd
    Pearl Harbor, HI
    15 TRD OR 4x4
    Well it looks like it's a stupid mistake. Outlet works just fine. My cord had got a little corrosion on it, so it worked when it was plugged in one way to the phone but not the other. Outlet and USB worked wonderfully on our road trip! Helped keep the kids' devices charged and was convenient for them.
