A/C Prematurely Cycling
Discussion in '2nd Gen. Tacomas (2005-2015)' started by inskie, Jan 30, 2013.
  1. Jan 30, 2013 at 8:51 AM
    inskie
    inskie [OP] New Member
    NC
    Toyota Tacoma
    We have a 11 Toyota Tacoma w/Access Cab 4 cylinder. The a/c will prematurely cycle (compressor on & off) on a regular basis. Have been to dealer at 4 times now, 1st response was automatic shutoff when on an incline (but it does it on a flat road) because of 4 cyl engine. Second time it was low on freon, so they added some. Still not right, took it back and they added dye. Took back today and they say everything meets Toyota specs and freon is fine. Has anyone had this kind of a problem with their a/c?
  2. Jan 30, 2013 at 8:53 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    welcome to TW! The A/C compressor wioll shut off under wide open throttle, and when its in use, it will cycle on/off as pressure demands dictate. Sounds all normal to me.
  3. Jan 30, 2013 at 9:40 AM
    inskie
    NC
    Toyota Tacoma
    I understand what you are saying, however it is not cooling the truck properly.
  4. Jan 30, 2013 at 9:52 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    low refrigerant pressure will do this.
    double-check 'low pressure port' pressure when engine is
    running, should build up between 30-40 psi...below 30 psi
    it will cycle like that....
    if pressure is fine, system needs major work (well, minor work...
    but the whole dash has to come apart to fix any of this crap)
  5. Jan 30, 2013 at 9:53 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    My a/c has always left a lot to be desired. I have had 10 year old cars that will freeze your butt cheeks to the seat, and brand new off the lot this truck a/c struggles to keep me cool even on a not so hot day. I have never bothered to take it in to get it looked at, so I have no idea why mine is that way.
  6. Jan 30, 2013 at 10:03 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    On hot days mine doesn't cool the interior very well. Its been like this since I bought it new.
