A/C PROBLEM RECIRCULATING BUTTON
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 1SolidTaco, Apr 17, 2012.
  1. Apr 17, 2012 at 12:16 AM
    1SolidTaco
    1SolidTaco [OP] Member
    GOT A 2005 TACOMA DOUBLE CAB W/77000 MILES, WHEN THE TRUCK IS ON, I TURN THE A/C ON WITH THE RECIRCULATING BUTTON ON, THERES A LOUD TAPPING NOISE COMING FROM BEHIND THE GLOVE BOX. THE NOISE STOPS WHEN YOU TURN OFF THE RECIRCULATING BUTTON...DOES ANYONE KNOW WHATS THE PROBLEM?..PLEASE HELP THANKS
  2. Oct 20, 2012 at 10:12 PM
    Desertninja
    Desertninja New Member
    California
    09 trd 4x4
    Hello, i was wondering if you found a solution to your problem, because my 2009 taco started doing this today. Im thinking its the air mix servo. Its faily easy to remove, i took mine out but i couldnt get it apart.
  3. Oct 20, 2012 at 10:58 PM
    Dr. Jim
    Dr. Jim New Member
    Northern California
    '05 Black Sand Pearl SR5 4X4 Double-Cab
    I have a 2005 double cab with the same issue...
    Where do I find the air mix servo? Can the AC run without the servo attached to verify the issue has been resolved?
  4. Oct 20, 2012 at 11:00 PM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    Sounds a lot like what happened to my 2008 Rabbit. The little motor that opens and closes the circulation flap had plastic gears on it that got jammed and was causing the motor to slip and cause the sound. Not sure where it is on the Tacoma, but it's likely to be the same issue.
  5. Oct 21, 2012 at 8:28 AM
    Desertninja
    California
    09 trd 4x4
    Dr. Jim, if you remove your glove compartment, the fresh air servo is on the left side of the blower motor. I did some research and i think what happens is that the motors travel distance is not being regulated due to some copper contacts inside not making contact. I pulled my motor off and plugged it in and i just kept spinning around and around. So even though the baffles are closed the motor just keeps going trying to keep closing the baffles. This is where the noise comes from. The only way i will know for sure is to replace the servo.
  6. Oct 21, 2012 at 8:33 AM
    Nunavut
    Nunavut Eh oh, Canada go.
    Canada
    DID YOUR MOTHER EVER TEACH YOU WHAT THE CAPS LOCK BUTTON IS FOR?
  7. Oct 22, 2012 at 11:02 AM
    Dr. Jim
    Dr. Jim New Member
    Northern California
    Thanks Desertninja - I appreciate the help...
  8. Oct 22, 2012 at 11:30 AM
    Spruced UP
    Spruced UP Well-Known Member
    Eric
    Jacksonville, FL
    2013 DCLB PreRunner TRD Sport, Spruce Mica
    Maybe that's why no one responded to this thread, way back then...
  9. Oct 22, 2012 at 11:51 AM
    Nunavut
    Canada
    I didn't realize this was such an old thread...
