A/C Problem with my 1997 Tacoma Xtra Cab
Discussion in '1st Gen. Tacomas (1995-2004)' started by Curlyc1, Jul 25, 2023.
  1. Jul 25, 2023 at 7:43 PM
    Curlyc1
    Curlyc1 [OP] Member
    Rick
    I have a 1997 Tacoma sr5 with 375,900 miles. It’s the 3.4 automatic transmission 4x4
    The problem is the a/c does not blow cold air. It has always blown ice cold then one day it just stopped.
    Here is what I have done so far.
    A. Tested the compressor and yes it work engages and disengages when the button is pushed
    B. Checked all the fuses and the relays all working.
    C. Checked the valve that controls hot in cold water flow under the hood and closes and opens properly.
    D. Took it to a mechanic who replaced everything but the condenser in front of the radiator and the compressor pump because it works just fine. The window in the condenser shows the Freon going by once I turn on the a/c switch. And I clean out the radiator with cleaner so nothing is plugged.
    E. Put on a new belts because I had to change the timing belt anyway.
    F. Since he had the dash apart checked for shorts
    This truck has always blown ice cold air for me and now that its 90 plus outside i need it to work like that again. Any help or ideas would be appreciated.
    Thanks
  2. Jul 25, 2023 at 7:48 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Welcome to TW… first thing we need to know is ,what are the low and high side pressure readings …. if the compressor is engaging
    ArizonaBrian and TnShooter like this.
  3. Jul 25, 2023 at 8:04 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Your saying it blows air but it's not cold or it doesn't blow any air?
    HondaGM likes this.
  4. Jul 25, 2023 at 8:09 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I wondered the same thing.
    But I figured the guy in step D surly wouldn’t replace all that stuff if it was a blower issue?
    HondaGM likes this.
  5. Jul 25, 2023 at 8:09 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    My guess the blend door is stuck on outside air sucking in the hot air across the heater core.
    HondaGM and Cloud99 like this.
  6. Jul 28, 2023 at 5:50 PM
    Curlyc1
    Curlyc1 [OP] Member
    Rick
    Thank you I for all the ideas so far but I forgot to mention the low read is 78 and the high 202 also it was 80 out when the reading were measured.
    Thanks you for idea of the blend door i checked and its working fine.
    Any other ideas would be appreciated.
    Thanks
  7. Jul 28, 2023 at 5:51 PM
    Curlyc1
    Curlyc1 [OP] Member
    Rick
    I checked the blower and it blows hot air just fine. When I move it to the cool position the air is not as hot.
  8. Jul 28, 2023 at 6:01 PM
    TnShooter
    Deogee
    STOCK
    I am pretty sure the 1st Gen trucks use a heater control valve.
    If it gets stuck open, it can cause the air to not blow cold.
    @Dm93 is the AC man. He can help you more.
    Dm93 likes this.
  9. Jul 28, 2023 at 6:08 PM
    Curlyc1
    Curlyc1 [OP] Member
    Rick
    TN shooter thank you and you are right about it having a valve but I have also tested that. Thank you though
    I look forward to hearing from @Dm93
    Thanks again
    Dm93 and TnShooter like this.
  10. Jul 28, 2023 at 6:10 PM
    TnShooter
    Deogee
    STOCK
    Good deal.
    Dm93 does AC all the time. (He lives in Texas. It’s hot in Texas. People need AC:rofl:)
    Dm93 likes this.
  11. Jul 28, 2023 at 7:06 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I wouldn't say I'm an expert on the subject but I know enough to get it done.
    The low side pressure is really high, high side is near normal maybe a bit high for 80 degree ambient.
    Typically you should see the low side in the 30-50 psi range depending on the system and how hot it is.
    High side can vary greatly depending on ambient temp but usually I see it in the 180-300 psi range , the hotter it is outside the higher it will be.
    Has the expansion valve been replaced?
    Was the proper amount of refrigerant put in?
    Typically with an overcharge you would see very high high side pressure and slightly high low side pressure and with an undercharge you would see both pressures low.
    Bivouac and TnShooter[QUOTED] like this.
  12. Jul 30, 2023 at 8:51 PM
    Curlyc1
    Curlyc1 [OP] Member
    Rick
    @Dm93
    I took it to a different shop and had them evac vacuum test and recharge the system. The new low reading are 33-48 and the new high 183 -200 the tech thinks the Freon was bad inside the system but could not give me a defining time answer. Also he put in a charge shot from a blue white can to make sure it was active when under pressure. The expansion valve has not been replaced yet unless you feel it is necessary the truck is blowing cold air.
    Any other ideas or thoughts would be appreciated.
    Thanks curlyc1
    Dm93 likes this.
  13. Jul 30, 2023 at 9:50 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    So it's cooling like it should now?
    Bivouac likes this.
  14. Jul 31, 2023 at 4:06 PM
    Curlyc1
    Curlyc1 [OP] Member
    Rick
    So far it’s working and cooling but i think time will tell if its fixed or not we are moving into another 90 degree day so it will be used a lot
    Thanks again for all your help
    Dm93 likes this.
