A/C problems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jstreet, Jul 1, 2024.
  1. Jul 1, 2024 at 2:53 PM
    Jstreet
    Jstreet [OP] New Member
    Josh
    2021 Tacoma
    I have a 2021 tacoma and I put A/C pro specially made for the tacoma however the driver side is cooler than the passenger side, is this normal?
    Thanks
  2. Jul 1, 2024 at 2:56 PM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Why are you having to add refrigerant to a 2021 Tacoma?
    Nope not normal and highly suspect. Welcome to TW.
  3. Jul 1, 2024 at 2:58 PM
    Jstreet
    Josh
    2021 Tacoma
    the other day I was sitting in the parking lot and all the sudden air and smoke came pouring out from the driver side and the a/c wasnt getting cold. I was told that the a/c need to be recharged and needed Freon
  4. Jul 1, 2024 at 3:24 PM
    Clinch Mountain Preacher
    Clinch Mountain Preacher Serpent handler
    3rd gen AC SR5 4x4
    Same thing happened to me. Including the driver's side blowing colder than passenger side.
    Turns out I had a VERY slow leak in one of the AC lines. Replaced the line and recharged freon and been good for over a year.
    Jstreet[QUOTED][OP] likes this.
  5. Jul 1, 2024 at 3:51 PM
    Jstreet
    Josh
    2021 Tacoma
    is this something I can do myself, or do I need to go to the dealer, I have a warranty on it however I have a deductible?
  6. Jul 1, 2024 at 4:04 PM
    3rd gen AC SR5 4x4
    It's an expensive fix..Cost me over $700
    I went to the dealer tho. The freon alone is very expensive. So make sure they diagnose it right the first time so you're not stuck doing the work multiple times over
  7. Jul 1, 2024 at 4:05 PM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    Warranty work if u got it . Not an easy fix .
