A/C question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by km87, Jun 6, 2021.
  1. Jun 6, 2021 at 5:43 AM
    km87
    km87 [OP] Well-Known Member
    Kurt
    Utah
    2005 Tacoma 4 cyl, 4WD, MT.
    Hey ya’ll,
    I would like your input in this real quick and my research is saying it can be a number of things, but nothing specific with mine.
    After the first 100 degree day my A/C stops working as well, of course. Usual story, driver’s side vents colder than the passenger side.
    Now the weird thing is this... I turn the A/C on and a faint hissing sound is made, but only for like 1-3 seconds. Every once in a while it comes and goes, but I maybe at the point of hearing things that aren’t there. What are your thoughts?
    I’m going on a road trip this Tuesday so I thought I would get it recharge from a local shop and have them add dye and take it from there.
  2. Jun 6, 2021 at 6:23 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Is that hissing sound coming from the passenger side? If so, it's probably the expansion valve opening and closing.
    The fact that it's cold on the driver's side and warmer as you move across the dash is typical of a low refrigerant condition. It's a sealed system, so if it's low, you have a leak.
    Craftsman makes a UV flashlight that will make the dye in the system glow if you have a leak. Sold at Lowes.
    Good luck
    Jimmyh and TnShooter like this.
  3. Jun 6, 2021 at 10:05 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Local shop may also check for your leak and make you aware it needs to be fixed before recharge. Recharging a system with a known leak is not ethical. So I guess it will depend on the shop and there method. So be prepared for that.
  4. Jun 6, 2021 at 3:06 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I agree with the others above. I had the same issue a few years ago and there was a leak in the HP Hose and Condenser.
    Repair leak(s) and then vacuum / recharge.
  5. Jun 8, 2021 at 8:42 PM
    km87
    Kurt
    Utah
    I got my a/c recharged today and well, the high pressure line was leaking like cray cray. I saw green goo under my tacoma and popped the hood with some good ole smoke or whatever it was. It looks like it was punctured by something that it shouldn't have been punctured by. Replacing this line, I do I need to get a new condenser for a new drier? I've looked and I am confused.
  6. Jun 8, 2021 at 11:00 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    On the Tacoma the Condenser and drier are made together as one unit. If the system is opened for service it is recommended to get a new drier and due to the condenser and drier being one unit you would need to replace them both.
    I know some that have not replaced the condenser/drier assembly... Your mileage may vary.
    https://macsmobileairclimate.org/20...-of-the-receiverdrier-in-your-cars-ac-system/
    Receiver/driers and accumulators rarely fail themselves, but as mentioned previously, need to be replaced whenever the system is opened for any other type of service.
    https://rivergatemuffler.com/2019/0...r-replaced-when-replacing-your-ac-compressor/
    When should you replace your AC dryer?
    As you can see, the AC dryer is very important to your AC system. So when should you replace it? The simple answer is this: the AC dryer should be replaced any time your AC system is opened for service. While this may seem unnecessary to some mechanics, most would agree that this is a good rule for replacing the AC dryer. In fact, most compressor warranties require that the dryer also be replaced if the AC system is worked on.
